  • Replies 7.5k
Posted Images
spotted MissR34's white beast yesterday rolling through my gheto in the north subs :) only i may drive a nice car in that hood thank u
hope you had your doors locked young lady :D
:blush:
and yes my doors are always locked
today within the hour of me driving home, spotted about 12 r33's!!!! including "theace" on salisbury hwy, also 2 r32's and this morning on the frost rd/main nth rd intersection r34 silver with nismo kit and bronze rims..........rekon it was the one i saw the other day
White 32 this morning, turning out of Clarendon Rd onto South Rd. Had black wheels similar to drift-teks but had polished rim, lowered exhaust etc. Drove next to him for a while in the SP23, anyone here?
Spotted I think OUTCAST on North East Rd near the Munno Para shopping center
Yep that was me...WoooHooOO!!!! I think we were looking at each other as I got a quick glimpse of your car going the other way.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
