  • Replies 7.5k
Posted Images
**BEWARE** Guys
Police are using skylines as pursuit vehicles undercover of course
there is this silver one and a white one getting round
it now can b put to rest this is not a cop car the guy works for bridgestone out north an unless his under cover in a factory its safe
an deluxe spotted ya last min seen u couple other times in Bwood area but i was in commo or red s14
Spotted my car on the back of a tow truck today at around 3:45. Written off... I'm shattered... Lady ran a red light and before I could stop, it was all over :D
oh dude im so sorry to hear that ;)
that's tough man... but lucky you're here to write about it.
Spotted my car on the back of a tow truck today at around 3:45. Written off... I'm shattered... Lady ran a red light and before I could stop, it was all over :)
damn, that sucks mate. At least you're alright though. Thats the important thing. Insurance cant replace you
Yeah it does suck, especially with the new turbs just going on but I am here to write about it and that's the main thing! Darren, I've definately had my share of dramas but no way would it ever stop me from owning one, I miss it already.
Probably go the GTR route next, wait for the payout, covered for $20g which is probably more than I would have got if I sold it. Just have to look at the positives :)
Anyone know a nice GTR for sale? :blush:
Hey Luke,
Sorry to hear man, that is not good.
Have you thought about trying to buy the wreck back as the turbo set up will probably make you your money back on the wreck.
Have thought about that Shaun and might do just that! Did you get the dremel from Kel? Sorry it's been so long, just been flat out with work and such...
Kietz, haven't really got a set price in mind but if the right one came along I'd definately be interested... you have an idea I take it?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
