  • Replies 7.5k
Posted Images
Down the carwash just now, white 33 pulled in with flame decals, chromies etc, the same one i see cruising with the hot blue 34 im in love with lol
Anyway got chatting with one of the guys, owns a black 34, they didnt know bout SAU so i had a chat, told em bout it, should have a few new members soon, hot cars :rofl:
Anyway got chatting with one of the guys, owns a black 34, they didnt know bout SAU so i had a chat, told em bout it, should have a few new members soon, hot cars :D
they were both on the ns cruise
i had to laugh at the 34 though had a GTR badge on the back and its a GTT and he had some god awful sound system going on in there too turned up full so its distorted heaps ;)
Lauren and Kye
saw rush33 drive past the bartley hotel while i was there suckin back a few.
Did notice ur rig sitting out the front, would have stopped in for a beer on the way back if i knew u were outside....
Just spotted PURESX on the front cover of the latest HOT4S mag.. Nice! .. Love the sub ;)
Pop on down to extreme horsepower show this weekend and check it out in the flesh!
flick here- R33PER do u work at the intencity at marion? Saw ur car and then i reckon it was u that served us at the counter. Was going to ask.. but thought i would look like a total moron if it wasnt u lol.
Was also going to leave a note on your window :)
Was also going to leave a note on your window :ermm:
haha yeah, i was going to ask if it was you also but thought i would have sounded insane if it wasnt :) recognised you from the first cruise i went on. hope you got your stuff without any dramas, kids are so indecisive lol
Spotted a white 33 gts's driving from morton road up elizabeth road (in morphett Vale) last night, forget the time, bout 1ish.. followed ya for a bit, then ya turned off.. car looked nice..
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
