We found the end of power at 23.5 psi. These are the last few pulls adding timing.
Precision 6766CEA ball bearing turbo. We are also working on a prototype exhaust housing " variable vane" to bring down the power band.
Edited by Weapon X
  • Replies 69
Posted Images
Ported head, 270 cams, Full Race with my waste gate setup on it I like heat away from the intake side, factory intake 1000cc Injector Dynamics , all the normal and a few tricks. I'm going to put another intake on and see what happens. And try some 110 cct.
Here's a vid for fun of a 2nd gear pull. Dyno tune was done in 4th funny how a tune changes in second.
= Edited by Weapon X
it would be hitting differet load points in 2nd on the dyno unless running a really slow ramp rate
Not a bad output for the boost and fuel.
Looks laggy though 23psi at 5750rpm and only revving to 8000rpm?
What is is that attached to the rear housing of the turbo?
Where you looking/working out boost?
Just going off 90mph where it looks like everything starts to happen... 90mph = 145kph = 5180rpm (300rwkw)
I can't exactly remember what speed 4th gear pulls, but that RPM doesn't seem right to me. That would make 4th gear top at 195KM/H at 7000RPM...
If you are sure that 145kph is 5180rpm then this graph is almost identical to my graph. Same response, same power.
Well not 100% sure, just using Paulr33's old RPM calculation.
Could well be wrong! :)
By those same number 142mph / 228kph / 8150rpm
Can't remember what 8000rpm is in 4th on my car off the top of my head :wacko:
Me either - cant remember exactly what it is.
Piggaz is good with gearing, enlighten sir paul :D
8000 RPM on our car is 235 IIRC.
Oh. I just had a search around and found a word document I have saved over the years.
145 kp/h isssss... 4850 RPM according to this.
3000 RPM = 85 HP
3500 RPM = 120 HP
4000 RPM = 160 HP
4500 RPM = 240 HP
5000 RPM = 415 ish HP
5500 RPM = 470 ish HP
6000 RPM = 545 HP
6500 RPM = 610 HP
7000 RPM = 660 HP
7500 RPM = 700 HP
7900 RPM or so = 733 HP
* Going off the brown line
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
