Well its a carbon copy of Elrodeo666's head which was good enough for 445 kw at 1.4 bar on -5's.
Have a look at the inlet ports on Brad's engine (SHOWOFFR32)... that is what they should look like.
BRB. I'll go tell the bloke that ported the HKS drag car that he did it wrong.
Go ahead... All I am suggesting is that the port looks polished from the photo.
To enhance mixture quality it is better to have a textured inlet port surface, especially considering you have massive injectors that wont atomise very well.
Well they proberbly are. But considering the guy has built mild to wild RB's day in and day out for the last 20 years, there must be a reason why he has done what he has done. Who know's what that reason is. I'll ask him in two weeks time when Marcus will sit him down and call me from Japan.
The guy in Japan who has done all the port/polish and r&d on the head has built more high powered full race engines, 9 sec drag engines and drift spec engines then most porn stars have ever had roots.
And yes its polished as well. Why..you'll need to ask him about it but as one of Japans top engine builders who has built 100's of high spec engines, I think he has a resonable idea of what he's doing.
But hey everyone has their opinions.
And Paul its 445kw @ 1.3bar
Just to be clear, your talking flow from a polished port vs fuel atomisation from a rough cut port right?
I figure the rate that Paul's car drinks E85 it probably won't make a lot of difference when its on song. Its not as though there are a lot of injector options to provide a streetable 2lt/min injector flow. The value of optimising fuel atomisation from porting/polishing methods could probably be weighed against the options available for injector spray patterns for similar effect.
Theres more going on with this head than just a port /polish job.
Been all machined up at Naprec to HKS race specs and then some custom work by HKS.
It has been designed purely for response and slamming his arse hard back in the seat and fro getting around a track nice and quick.
Pauls head has a bit more done to it than mine and has been built to handle 600~650kw if he ever chooses to go down that path.
Anyway this is Pauls build so wait a few weeks and he'll let you see whats what and at the end of the day it all comes down to what it does when it's all bolted together and tuned properly.
It will be interesting to see how it all ends up..
Hopefully one day maybe a V-cam and those new turb's that Gav has, it would be quite an animal.
Unfortunate about the old engine!
But it will certainly be interesting to see how this new setup performs in relation to the old setup. Especially with the addition of the new head. What sort of port job was done to the old head?
My mates car runs low 9's with a near std head, ports are just cleaned up. Makes about 880rwhp. What bigmikespec has said holds true, port finish 101 regardless of head type or setup usually doesn't go any finer finish then 80grit. Polishing the surface slows air speed and ruins mixture motion through the port. But maybe this particular guy has a formula that works for him and it goes against the theory that everybody else in the world works around. It will be interesting to see if it makes a difference or not.
Gotta keep an open mind about everything!
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
