Took a few pics of the clutch last night
Flywheel
One of the plates
Cover
Done ATLEST 250 7000 RPM + launches. Feels the same as the day I took ownership of the car. It's going straight back in. Very very surprised at the condition of the plates.
Another reason why i am so happy i spent the money on one of these clutches comp spec ftw
Paul, good to see that u stuck with the 2.8. The 3ltr will ruin your gtr due to the mods required with cutting and drilling and stuffing around, you have such a nice example r33...if your car was clapped out then I'd say go to a 3ltr.
Unfortunately when u get the horsepower bug, things break (as per Ian's comment earlier).
Im not a big fan of polished ports.
Heated Air = increased viscosity = extra drag through a smooth port. this has been proven.
I have had my Rb26 head flowed to its maximum ablity without any polishing
Yes it has!
When you look at the list of high powered engines this guy has developed in the last 15 years in Japan from the Drag33 to time attack engines down to current GTR35, you know he has got a little bit of knowledge of what he's doing, plus he's got the runs on the board having built literally 100's of race engines and high performance cars.
End of the day its the complete package that makes everything come together to give a car that has buckets of torque, great power delivery on low boost and isnt going to go bang.
Also you might want to have a real good look at a few other top Japanese engine builders like Jun etc and see what they do.
Are they doing it or have they done it wrong ??
These guys were pushing the boundries of the RB before most owners here were out of wetting their beds.
Its easy to say yes this is proven and thats proven but how many of you guys have built engines and own cars like these guys in Japan have built and still do.
Have you guys actually been and seen what the Jap top tuners build ???
For example in Australia how many 9 sec cars are there..Japan 10 years ago they were being pumped out left right and centre.
Nowdays hardly any and thats due to economic differences e.g Japan is going down the tube big time so nobody has the coin anymore.
Sadly the RB in Japan today is a dinasaur, alike to the old golden Holden 308 , yes parts are still available and the odd build still happens but this is due to just being for bread and butter money. The focus now and the in future is well and truly the GTR35.
At the end of the day you have to look at what Pauls building here. This is not a knuckledragger engine, its being built for all round high performance and high response so he can take it out to the circuit and go very quick but still enjoy a Sunday drive but have all sorts of anger under the loud pedal.
He might have a little bit of knowledge but if those inlet ports are polished (which they kind of look like they are) there are deficiencies in how that inlet port will perform... that is the bottom line, it is FACT! Whether he has built 10 engines or 100 means nothing. Plus the fact that this head also has +1.5mm inlet valves is a whole other issue...
I don't think it is right to continue this on Piggaz's thread, apologies mate. Marcus send me a PM or email if you like.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
