just finished reading the thread ( holy shit, frikin awesome build ) and your drawing the line at shocks ? really ?
Depends on how firm they are. I have Marcus's shocks lined up so I might throw them in and see which I like/prefer.
.... I don't know if that coating is going to last Paul. I mean look at it...
But ah... I don't want to burst your bubble or anything...
LOL. You're a jerk!
You deserve a chin shot for that!
Got your brakes yet farken?
