yeaaahh... what the hells going on Paul? Farken..
(did I do that right?)
Only 40 days to World Time Attack and I want a drive (I mean ride...). Don't let me down.
Matty, I'll do my best mate.
If not.... it's beers and beers and beers. *burp*. :D
Nice one mate, glad to see its coming along well. Hurry up and join the club where we actually get to drive our GTRs...!
If youre not working late every, single, night, youre not working hard enough.
Paul, do you know your cam centerlines on your old head? If so, can you share?
Not sure, but we are getting all the cams measured up and plotted on paper. I'll post that sheet when I get it.
I need the engine back so I can do anything :(
Any idea how your cam gears were adjusted?
Intake was quite hard advanced, something like + 10 or so degrees, exhaust was -1 I think.
That was setup for GT-RS's. When I went to -5's we didn't touch them.
What sort of timeframe do you think you are looking at? I have only taken mine for one outing since getting it back so we may need to take both of them out soon to rack up some km's :)
Weather's been rubbish anyway and given how the car behaves in the dry id rather not risk death by trying it out in the wet! - Yours will no doubt be even more nasty
No build thread Marko and I don't want to clutter Paul's but yes ive just finished a build and Dart was involved, along with a few other workshops.
I may put up some details and a thread if time is ever on my side.
Nick
Nick, I don't know man. I said 6 weeks... 6 weeks ago. Can't be too much longer. I've lost a little motivation at the moment but I'm sure that will change when the engine is 2 meters in the air!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
