Still waiting the phone call for the engine. Yavuz has one of my JUN cams for a little bit of "R&D". More on this later on :D
However a Precision 6466 CEA Twin Scroll 0.84 got ordered today. Didn't see that coming hey mate ;). Nor did I two weeks ago! Haha
that was definitely out of left field, I thought for sure you would say twins, but I've seen this sort of thing before, first it's a big single then it's No2 and before you know it there is a 3.0 on its way :yes:
I agree... All I can remember is .... -5's -5's....
In the end it doesn't really matter... Just don't take too long in making it drive again. Have the car off the road for too long while changing too many things and you will lose the passion for it.
Or worse, You'll do something really silly like spending an extra $30-40K on it, and then end up selling it!
Oh i know, but when a little SR is beating your -5 graph both down low and up high with one of these things, not to mention Jez's result it's really saying something.
If it's a huge flop then nothing is stopping from bolting the little baby -5's back on.
No N20. It's not "street legal" :woot:
If the 6466 is too big i'll just pull it off and buy a 6262 or 6266. Keep that turbo for Motive DVD event's.
it's only illegal if you get caught, :yes: I notice there was no denying the eventual possible use of a 3.0 though :whistling:
This is exactly what my god brother did back in the 80s as I remember as a kid. Built a HQ monaro with a blown 454 and in the end after spending a lot of money as all parts were from the US - he sold it in parts. All he had to do was assemble the thing.
Paul - good on ya for going single. You are chasing top level results and I'd it means using a single, so be it :)
Don't sell your -5s just in case.
Nah Marko. The 5's and all the pipe work will go on a shelf in the garage all wrapped up. The condition is that this precision must beat the -5's in all areas!
Jez matched the -7's with a 6262, you'd think I can match -5'a with the next size up.
Also, spoken to Yavuz about engineering it AND passing emissions. That was another 'condition'. Both he said would be no problem.
pop the bonnet please sir..........
Should sound sweet :D
The first day he drives it out if UE with a single he'll get pulled over haha
Hopefully not (touch wood) :D
Let's get this beast on the road!!!
Narrowed down what manifolds to use Paul?
Lol. Don't say that man! Yavuz said he will engineer it also.
Not yet. Can you only get full race manifolds from the states or is there a local distributor?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
