I no, i mite one day come to like them if I can sort what ever is wrong with the dam things.
Anyone got any sudjustions ?
Any "up, down, up's" in size in the exhaust?
Cam timing?
Tired engine?
Should be bout same as mine as almost same set up , i think should change cam timing to what mine is :)
The exhuast was farked when it made 330rwkw, 2.3inch front pipes into a 3inch catback than went down to 2.5inch in the cannon.
It's now got 3inch tuned length front pipes into a 3.5inch merge. Decat, and I'm just waiting on the 3.5inch tomei ti catback to turn up.
See how it all works out when the new system on bolted up. Than jez can do a full tune on it, cam gears, and all.
It's got type b pon cams.
Azza's made awesome power on the same setup I the same dyno.
His got a forged motor, but my motor is 160 across all 6 so it shouldn't b an issue.
C what happens
Not exactly the turbo's fault with the little 5's trying to blow out of that man.
So what's considered responsive with -5's? 1 bar at 3600 rpm?
from memory my rb2630 with -10s made 1bar @ 3krpm, I'd need to dig it up as I posted my results in each gear on gtr UK forum
Yea I no, the prob I had was I made up at 4inch system took it back to the dyno and only made 7kw more.
Im just saying -5 on something like your motor is crazy. It deserves a decent turbo. Gunna b awesome!!
Next time your under the bonnet man, could u have a look at what yours are set at? Maybe take a pic?
Let me know when your back and i will meet you at Jez' s and we will have a look :cheers:
You won't get that on a 2.6l unless it's fully loaded up :)
On the street it's around 4000-4200rpm in 3rd for a 2.6l if memory serves me correct
u are the first unhappy -5 customer I have heard...am I allowed to ask who is your tuner?
Add me to the list then for street/hill runs/motorkhana stuff the -5s are shithouse on a 2.6l
Cars was significantly faster with the smaller turbos coming on much faster in a on/off throttle scenario as -5s are lazy and need a stroker.
Interesting as I found my other gtr with -5s very responsive. That was a 2.6 as well.
What do u think is a good turbo for the application u refer to above?
Its not a loaded question- just like to hear your opinion.
Well given I've said many times over that I had -9s taken off to put the -5s on (so i can comment on both, unlike most)... Wouldn't say it's particularly difficult to come to such a conclusion :merli:
I've had GTSS, GTRS & -5's on a 2.6ltr (as well as -10s on a 26/30 which Paul has driven).
^ Absolutely you can comment on -9's back2back with -5's as you've had both...really is horses for courses though as I personally found GTSS's way too small (not sure how -9's compare to GTSS though)
I think it depends on the sort of driving you do. Guys that do the 'on/off/on' driving IE hillclimbs, skid pan work and track work will always favour the small stuff.
Steveo overlayed a 2.6 with SS's and my 2.8 with 5's and down low they were pretty much the same. Top end, well we know what happened.
2.6 with -5's is still lethargic, however peoples definitions of being lazy/lethargic/laggy are all different.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
