I used that shell oil you get in the red container...the one you see at servo's all the time - for my run in. ~$40bucks for 10L, you can't really go wrong.
Diesel oil would be fine, but the extra detergents wouldn't really be doing anything as the engine should already be sqeaky clean!!!!
Keen to see the results for this (re)build!
Edited by wedge_r34gtr
Few things to do my ass.
Lol. I was at unigroup and saw what you brought there!!!!
PS: your front cam cover looks great!! :D
Haha. a lot of the things on the list is small stuff. I had to list them otherwise Tyson would forget!!
Yeah it turned out well. Very happy with it :D
Where is yours upto?
Penrite HPR30. It's loaded with the most zinc of any oil on the market, making it perfect for run-in of camshafts/bottom end etc.
That's what I've just put in mine!
Penrite HPR30
zinc - 0.11%
I just put this in ....Why wouldn't you use this ?
Penrite Running In Oil 15/40
zinc - 0.161%
I was pulling front diffs apart today... Bottom end is also ready for assembly.
Penrite HPR30
zinc - 0.11%
zinc - 0.161%
I think that is what I ran, pen rite run in oil. Your engine builder should guide you on what oil to use for run in
Look at a radiator filter while your getting it ready, after my rebuild it caught a fair bit or sealants and other crap, even after the chemical clean it still collects bits of crud that would have other wise gone through the water pump and maybe got stuck in the radiator.
TEFBA Radiator / Cooling system Filters
Like dis > http://www.ebay.com....=item20bddab6b4
Disclaimer: The RB30 that went into my boat was probably 30 yrs old and no matter how much cleaning you get done it will not remove all the old broken down rusty crap that has had that time to build up inside its cooling system, which it seems, is quite alot.
P.S. Numbers Farkern
I have one mate. I can't get the bloody thing open haha.
Going out tomorrow to see what the latest is. w00!
Here is something interesting
Here I was stressing about valve to piston clearence with the 1.5mm OS valves. Now with a 0.9 mm head gasket (smallest I could find), squish of 29 thou and cams with over 10.8 mm of lift the clearence on the intake was 2.2 mm and OVER 3 mm on the exhaust. I could have not relieved them :( So much for Tomei's "Over 10.8 mm relieve the pistons" GRRRRRRRRRRRR
Hi Piggaz,
just curious what your cam centerlines, lift and duration were set at for this
OK. I was out there today, all coming along. New oil cooler core and lines were going in. I changed the core because the old one would have been full of N1 oil pump gears!
I suspect startup and run in is Monday/Tuesday. I have some pics that I took today so i'll throw them up soon.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
