Its a strange one Marcus. On the dyno it's at the same rpm every time (7000). It's not a hard cut or a "rpm cut", but a faint miss. The best way to describe it would be three softest rev limiter ever.
In the road however, depending on how cool it is, it may happen earlier. Gtr Sean drove it before we left for the nats and it missed at 5800. Stupid car.
Make sure you get Yavus to check the settings for ignition/dwell etc. It's the only thing (computer) that has been changed....
I was there today. Tried that one too. :(
Didn't you just replace the alternator? Could the new one be playing up?
Not a chance of that ! 20 mins before it came off my car and it was pumping at full power output. She is almost brand new unit and designed for high power GTR's.
It should be boosting electrical output.
Chuck it on Paul and recheck all your earthing.
CDI time !
Naw wouldn't go that route either. I have a 500R on my 'mini-me' version of Paul's and mine has break-down once it's hot. Hard to nail this one down. Just not sure how to get a hotter spark with lots of amps to make it fire reliably.
Was good to see you lay a decent time there Paul. I'm spewing a bit cause I had to drop out of play so soon. Might have been able to give you at least a little run on times.
Is that not more likely coils then? What coils were you driving with the 500r?
Yeah, your issue is a strange one considering you have tried another set of coils and it didn't change anything :(
I reckon the issue might be the ecu, specifically the fact you're running wasted spark... it'll be over working you ignition system IMO
Thing is, it was perfectly fine 9 months ago. It's pretty much a standard setup bar the igniter which has been modified. Joey has three exact same setup and no issues.
Hi paul
How does the car feel with the higher comp and tight squish ?
Feels really grunty. No need to rev it. I would have liked more comp but without custom pistons it wasnt going to happen.
It will be a few weeks before the tune is finished.
paul,
have you whacked another set of working coil packs or an igniter on the car to test yet?
Yep with coils that just did 425 rwkw a few hours before. Changed ignitor box off the same car. Changed plugs. Then I yelled at it!
Fancy trigger wheel all in check?
Doesnt seem to be any issues there man. Nothing on the logs.
I'm sure it's something silly thats been overlooked due to a serious lack of time.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
