Thats right Allan. Farken whopper of a collection it is too :D.
Update... sorta. Spoke to Yavuz today. Car is going back in to try and find this dirty misfire in about two weeks or so. Gives me a bit of time to take it for a few more drives and put some kms on it.... Not to mention the 200 litres of so of E85 sitting in the garage.
sweet. Any progress is good progress :)
should hopefully be down in the new year for work. May have to drop by for a 'few million trillion ales, shots, buckets, cocktails and anything else you can think of'
Fixed :D
