Right. I'm wid ya now. Sounds like a mission to change it.
Why after maket diff? What's wrong with the vspec one?
Since putting the Quiafe up the front, the rear is single pegging sometimes. Having so much more grip up the front must be throwing the standard computers into "f**ked if i know whats going on, so i'm just gonna single peg".
Right I understand. I'm assuming quiafe does manufacture a matching rear diff now?
Right I understand. I'm assuming quiafe does not manufacture a matching rear diff now?
Edited by Ants
They do. It got released about March. It was a toss up between that or the Nismo. I went the Nismo.
Nissan seem to love randomly swapping between bolt patterns on those shafts
Its farken stupid. Nissan give you new flanges in the box. Whats the point when they dont line up with my original shafts? ARGH!
i have a spare set of non v spec shafts for sale if you get desperate
hihihih shaft!
Thanks Pete. I think Terry has found a set, ill know more later on today. Fkn Nissan Fkn.
Diff is in, clunk clunk, bang, clunk, clunk. Sounds mad :D! Did a whole heap of figure 8's and by the time i got home it's starting to settle down a tad which surprised me. BUT, now my 4WD aint working! What have we missed?
Would getting a matching quaife rear diff have been any easier in hindsight, or would you have always had the issue being that you had v-spec to start with?
Negative. Still need the non homo spec rear housing and shafts. Ill give it a bleed over the weekend.
Stupid v spec. Everything that originally made my car one is now gone apart from the quicker ATTESSA computer.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
