The funny thing is whenever u stepped on it, u had to turn it 1/4 turn to the right - i know that the back wheel was out of alignment but this was the same as Domonic Russo's yellow r32 gtr which was making 650awkw where he had to counter steer to keep it straight.
GTR's get massive torque steer in the front with decent power. Check out this video (the wheel alignment is spot on), in the first 3 gears it moves over a car length left and then in 4th I actually drive back onto the "racing line"
Edited by SimonR32
Rightio. The suspension stuff got started today. The sperm whale got weighed and some of the geometry measurements taken today. The porkie pig comes in at 1580 Kg with 1/4 tank of fuel. A little lighter than I thought. The only thing I have taken out is the spare wheel, jack and some of the boot lining. Apart from that it's all standard.
FC872F61-6E4E-47C9-8B47-F98E1F01BA01-662
74F8DCD0-DFD7-4B30-B5E4-D508B9FDFC4A-662
11ty strings everywhere. Tomorrow the shocks will come out so they can measure travel of this that and the other then go away and put together a combo. It'll be basiccally setup for "tarmac rally" which is pretty much what i'm doing with it. Hillclimbs and goat tracks like Wakefield park. Turn around time is between 2 and 4 weeks depending on what Bilstien has in the country.
Well isnt the r34 the heaviest of the gtrs?
Wat lap times u aiming for at wakefield?
Yeah they are, but an extra 20 Kg IIRC.
Times, who knows. I did a 1:10.02 revving to 5000 RPM last year. I solid 1:06 would be nice. It's the muppet behind the wheel that needs to practice :P
the 33 is the heaviest, my 34 came in at 1480 with 1/3 tank, but the tar was removed before I brought it
I remember your blue 34 in the garage.. Very nice.
I could have sworn the 32 was the only Gtr under 1500kgs
that is also what I thought/read
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
