The funny thing is whenever u stepped on it, u had to turn it 1/4 turn to the right - i know that the back wheel was out of alignment but this was the same as Domonic Russo's yellow r32 gtr which was making 650awkw where he had to counter steer to keep it straight.
GTR's get massive torque steer in the front with decent power. Check out this video (the wheel alignment is spot on), in the first 3 gears it moves over a car length left and then in 4th I actually drive back onto the "racing line"
Edited by SimonR32
Rightio. The suspension stuff got started today. The sperm whale got weighed and some of the geometry measurements taken today. The porkie pig comes in at 1580 Kg with 1/4 tank of fuel. A little lighter than I thought. The only thing I have taken out is the spare wheel, jack and some of the boot lining. Apart from that it's all standard.
FC872F61-6E4E-47C9-8B47-F98E1F01BA01-662
74F8DCD0-DFD7-4B30-B5E4-D508B9FDFC4A-662
11ty strings everywhere. Tomorrow the shocks will come out so they can measure travel of this that and the other then go away and put together a combo. It'll be basiccally setup for "tarmac rally" which is pretty much what i'm doing with it. Hillclimbs and goat tracks like Wakefield park. Turn around time is between 2 and 4 weeks depending on what Bilstien has in the country.
Well isnt the r34 the heaviest of the gtrs?
Wat lap times u aiming for at wakefield?
Yeah they are, but an extra 20 Kg IIRC.
Times, who knows. I did a 1:10.02 revving to 5000 RPM last year. I solid 1:06 would be nice. It's the muppet behind the wheel that needs to practice :P
the 33 is the heaviest, my 34 came in at 1480 with 1/3 tank, but the tar was removed before I brought it
I remember your blue 34 in the garage.. Very nice.
I could have sworn the 32 was the only Gtr under 1500kgs
that is also what I thought/read
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
