83747408-BDED-481D-A4E9-C644DF3AA119-142
Picture I took this morning with all the covers on. Still need to order a new radiator shroud though.
Also one of those radiator deflector thingos to cover up the horns and A/C fan etc :)
Stop being a lazy fkr and come pick it up :)
Yeah, ill get there!. Time has not been on my side! Grr.
Question for you Nick. Where is your GT PRO set to? Mines at Medium and it's one aggressive mofo. I may need to back it off a tad.
I need to find an ARC one. Not a fan of homo carbon crap.
I was trying to get an ARC one originally but come across my Alloy one on Ebay randomly! Was already sprayed black too :woot:
Black... The new... Shiney? Lol
I remember when first speaking to Alex @ Plazmaman about 3 years ago and i was ordering the stealth kit and he said that Black was to be the new Chrome :P Its Black Bling!
Id have to check with the boys that installed it, im not too sure
raidator guide
tits on a bull
Not when you are talking about the cosmetic stock looking finish! When you pop the bonnet and look down it look a bit average without it! He has gone so far with the presentation it might as well be finished off properly ;)
question, how does the air get to the air box intake if you block the airs path from the grill with the radiator guide ?
You can see the big gap in mine so it would still flow plenty of air... Although I haven't worked out a snorkel setup for mine as I wasn't clever enough to use a stock airbox :(
Oh yeah, scrap that idea!
Im sure brad at profab would be able to fab one up out of sheet ally and in corporate a funnel to the air intake from the front grill.
Then just paint it or powder coat it the new shiney lol.
:yes:
Mine had a shield/guide but it also had a 100mm hole in the guard with some NACA duct tubbing from under the air filter shield to the front grill, plus there is a heap of air voids around the front headlight to allow air to flow inside the air box if it has a opening on the front side behind the headlights.
No good for the ARC box I believe though, but good for a enclosed pod set up.
LOL, just saying.
Rightio. SO after 2 days of 11ty strings around and under the car, deflection gauges, tape measures, more strings, more measuring and even MORE STRINGS, I have a piece of paper with words and graphs. 7 pages of graphs and jargon that I hardly know what it meant.
From what I CAN gather from it. I will need to purchase a roll centre adjuster setup for the front. the HICAS lockout bar needs to be moved up 10ish mm to help eliminate bump steer in the rear. (Design fault possibly). The shocks will be Bilstien with a PSS9 body - That's where the similarity will end. From then on its all Dejan's specs. His valving, gas, spring and oil combo. People may laugh, but the spring rate in these will be about 20 KG/mm BUT it will be very pleasant on the street. They will be height adjustable and damper adjustable.
A little bit of testing and these will be available for R33 GTR's as a bolt in kit.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
