Yeah sorry that's my bad, A v8 is what was said and my father in law has A v8 and Paul makes more rwkws at 3000 then that v8 makes peak at the fly
That said spend the kind of coin I guesstimate Paul has making his the machine it is to a V8 and between 2-3000 rpm you'd be pissin in the wind trying to match it
Thanks Moose :).
A V8 is always gonna feel better low down on the street though. That's just how it is. It's definately nippy ;).
Haha nippy! You been hanging around me too long! My baby 270kw Evo is nippy the sperminator bitch slaps you in the forehead when she comes on! ;)
So, the dampers arrived but Dejan didn't order the pillow tops as he thought we would reuse my current ones. Only issue is, how do I sell my Nismo's without tops? Errrr. So new Bilstien ones were ordered.... Wern't cheap. Now, just my luck, the guy that assembled the dampers wants to put these tops on. Something to do with the height of something (not sure why Dejan can't put them on but anyway....). This guy however is on a flight to god knows where and won't be back till Tuesday. Grrrrr
So now the plan is, install everything on Wednesday, modify the HICAS lockout bar to move up then point the wheels in the right direction on Thursday.
Just got home after unbeaching the whale off Unigroup's shores.
Suspension feel's incredible. It's on number 2 of 8 or 9. Soaks up bumps and stuff with ease. Very progressive in how it breaks traction too. You can almost "feel" when its about to go. On hard breaking, the nervous and wandering around rear end is gone completely! Having said that, there was a few little geometry changes which would have helped eliminate that.
We ended up with spring rates of 14 kg/mm on the front and 9 kg/mm at the rear. Feels softer (and definately more compliant) than the Nismo S Tunes I had in there a few years ago.
The car is sitting fractionally lower than what it was before, but, no problems over speed humps and driveways. Thank god! I made sure Dejan knew it's not a time attack/track pig!
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
