So about the gearbox, though I'm sure this is propaganda and maybe even doctored or false (lol) but this video helped me choose a PPG helical dog box.
All-in the thing ran $12k usd
PPG 1-5 hel-dogs
Billet forks
Billet OS giken center plate
Billet large spline input shaft
New bearings
Labour for shepherd transmissions to install.
Shipping from USA to Canada including customs
I have give or take the same power (2.8L also) and tall gears. I have yet to drive it (machining engine) but should be ok...
Hope I don't need to rebuild it too often, I took a huge paycut and have 2 kids now lol.
I am currently looking for gearbox cooling options and expansion tank (leading cause for PPG fails is supposedly oil starvation which is surprisingly not warranted, word is oil gets slung into the breather and spit out until the level is low enough to cause problems.... I dunno.
I got tired of swapping stock gearboxes...
I have flatshift and launch control. So we'll see how to goes.
  • Like 1
its a well know fact that a aussi product when shipped to the usa then shipped back are cheaper than buying loacally
lol
And this is why no one supports local manufacturers.
It also disproves the nonsense that local products are priced as competitively as claimed.
