Why did you build a 2.8 and use an n1 pump haha, was lucky you made it that long without letting go!
I bought the car off a mate like that. That engine was built in 2005. It was always the one thing that I was worried about.
And I kept telling ya I had a tomei one under the bed with your name on it whenever you wanted it.
On a serious note, could the damage to the box have been done previously (pre this engine rebuild) when possibly the owner gave the car a bit of hiding now and again.
I'm talking possible microscopic stress fractures that may not have been visible during the boxes recent rebuild and with the new sandwich plate and diffs maybe no torsional give, well something gave.
Maybe time to pull that black carbon giant dildo out again that could help with torsional loading ???
Whats the damage diagnosis ?
Marcus, I built this box about 5 years ago when I smashed the OEM box. That was a shock loading through my own fault.
That big dildo is long gone. Stupid POS!
Need to get it out and inspect. If (hoping) the gearset has survived (not liking my chances) ill put new bearings through it and whatever has failed then screw it back together, but from what Terry has said, it's a shock loading more than likely. When I did it, I'm not sure.
Not sure when I'll get to it with Xmas and shit coming up. The plan is ill wash it and drain the E85 out of it and flush with some 98. The car ain't going anywhere so ill just take my time.
We already told you to get an Air Shifted HKS box........... stop being a pussy
And i dont care if you cant downshift :P
Is that what we decided? I don't remember.... No idea why! :D
What about this mad RH9 box : http://www.rh9.or.jp/original-product/products-list_mission.html
The one at the top of the page. Chuck the link into google translate as can't be bothered translating as been speaking too much ping pong of late and on the beers.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
