I realise the banks don't care, they're only after one thing and it aint your well being. I realise the extra *whatever amount* is a drop in the ocean but then you're paying interest on that amount for the life of the loan. I don't know about you, but I don't want to be paying a gearbox off in 15 years time. lol.
It's the banks money which you're paying back. Redrawing for stuff like extensions (when renting it out) or to purchase shares, yep totally, as that's tax deductible. To pull out for a gearbox, you'd have to have rocks in your head.
Hurry up and screw some boost into yours will ya :D
boost won't be turned up till you get your new gbox :P
I was referring to the OS88 cuz we all know a standard box in Sperm whale will last oh say maybe a day :D
I'll "turn it down" to its minimum. 420 on gate pressure with 98. :(. Might have to turn the controller on and soften the gain up. Haha
still awesome numbers Paullie on 98
I think common sense and a bit of kindness to the standard box will help ya mate
Not really cheap. Its 2k cheaper than a new one ex japan.
Keep in mind everything in japan went up by 3% as of April 1st with new sales tax hike.
Another 2% due in September. :verymad:
Where did you get that info from, Paul?
If [NITTO] R34 can thrash 3.2L's worth of power and torque through one, then that is plenty tough enough :D
I will just leave these here:
http://www.youtube.com/embed/JRzlLnqsVj4
http://www.youtube.com/embed/bjyb6d6t2dw
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
