This would speed up the process ;)
Rightio.
I've been offered $19 K with a working head that has V cam. If it's not sold on here it will go to this certain guy, he just can't do it at the moment. So I'm not fussed if it doesn't move.
Might sound like a lot but
GT block - two on here for sale for $10k
Stroker - another $7k
Head cost me $11k
Marcus also sold his engine that was very similar just in a N1 block for $18K iirc two weeks ago.
Rightio.
Head cost me $11k
ah so Marcus finally sold his engine
Almost took him a year
Also yeah that's a lot Paul :D
Rightio.
Head cost me $11k
Try build it for that price though, good luck!
I bet your motor probably cost as much and you got stock crank, stock springs & lower than factory compression ratio and blowy poncams ;) Edited by Mick_o
Nup. My motor cost a LOT less than that lol.
Rightio.
Head cost me $11k
Paul it went for a fair bit more than that plus a stock engine and all gear to turn my car back to stock.
Wasn't advertised, just word of mouth and went to very appreciative owner.
What people don't get is that to get the sort of responsive power that Pauls engine has costs $$$ and time.
Anyone can build a peak power engine but to build one that gives you that nice big fat torque hit sorts the real engine builders out from the wannabees. Straight line grunt, pfft...you want a drivers car that gives race engine performance every time the loud pedal gets touched and will do it all day long.
You can bang your head all day arguing the point but proof is best kept to actual bum in seat feel but all passengers must wear a nappy as you'll soon get sick of cleaning shit stains off the passenger seat.
What Paul's planning now will be a very special and unique package and engines like these are far and few between because there are no short cuts, plain and simple they cost $$$, a lot of time and frustration.
  • Like 1
this ^ has now got me intrigued
Im gonna guess and say that he's going for RB 3.5, with GTX2863r with -5 comp housings, OS88 tranny in an R34 GTR
Yeah the next package will be pure insanity and super special i cant wait!
I can tell you from the drivers seat that the 2.8L is absolutely insane it free revs like an roadbike engine! A tiny blip on the throttle and the needle shoots off to redline as quick as you can blink! In any gear from 2nd gear and 4000rpm HANG THE f**k ON to that steering wheel as shit around you gets blurry and things start coming up REALLY fast!
Ive been in all kinds of wound up stock 2.6s and nothing is remotely as ferocious as this thing is! If you think that your 500kw 2.6L will touch this car you're dreaming as it just makes grunt like nothing I've ever experienced its sad to see it go as it really is a rare engine and theres definitely not another engine around like this thing.
  • Like 1
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
