I'm from Brisbane Qld, sorry for the question as I haven't read my os giken booklet. But once you engage reverse by pulling the lever up do you have to put the lever up again to go back to neutral or do you just push the lever down as you would when engage the next gears?
From reverse you still have to hold up to neutral. From neutral you just pull back for first.
It definitely changes the car from the tall geared OS 5 speed that I had in it. "Woke it up" as such.
You don't need to run the OS clutches, but it takes out one less headache when putting it all together. I looked into trying to salvage the coppermix as they really are THE clutch to have in a road going GTR. (Mine was in there since 2005 with no service/rebuild at all). It was all too hard. For starters the coppermix was a pull type, this box only has the bosses for a push type, then there was the bigger input shaft issue. The R3C is awesome, much better than expected and NOT how I remember the R3C in other cars I've driven. The pickup/friction point is quite low compared to the Coppermix which takes a bit of time to get used to. Apparently this is the new type. What they have changed, I'm not sure.
You will need to supply your own transfer case.
There are 4 gear options available. I went option 2. Assuming a 265/35x18 tyre and spinning to 8000 rpm each gear will go to
82
118
160
200
234 (same as stock as its 1:1)
310 (same as a factory 5 speed as its 0.757)
You're basically slotting an extra gear in before the 4th gear in a factory 5 speed box. If that makes sense.
With the box, I bought;
Box itself
Modified cross member
Bent shifter
Clutch
Release bearing
Clutch aligning tool
There is a bit of crashing and banging at low rpm, but that's just me not getting the timing 100%. I've only driven 60 kms or so with it so still very much a noob. Up high and drive it like its stolen, smooth as silk. Just slides into the next gear, you don't feel anything through the shifter. As quickly as you can pull back on the gear stick its in. I've found preloading the stick before you lift seems to work well too. I'm still clutching in ATM but as time goes on I'm sure I'll be able to do the no clutch/ lift throttle technique. I'm obviously not tuning a strain gauge - yet. I wouldn't like to daily drive it but for a weekend car it's great!
Thanks a ton. This post will help a lot of other crazy people like us!
Marcus!
It will happen, just a case of when.
Have you changed your number? I rang you a few weeks ago.
Got a gold mine lease so away a lot digging holes, blowing crap up.
Give us a tingle when you get the chance, boss.
Will do champ..bit crazy at the mo but asap.
Lol that's awesome Marcus! Just gotta try stay sober now
Why ?? Alcohol and explosives.. what more can you ask for ..cracker night on steroids !! :cheers: :cheers: :cheers: :cheers:
  • Like 1
  • 1 month later...
Have been a little quiet here lately. This fuel gunk issue has really given me the shits. The baskets in the injectors kept filling up so in the end I decided to rip them out for the journey to Richmond where the next round of goodies are going on.
20220004-9318-4519-BA51-1EA194886659_zps
37834A2D-20B0-4E50-8D5D-E1F834E6C988_zps
BA2A1B01-BBB6-4181-AC44-442F28C6499A_zps
EFR 8374 1.05 ass end. See you later -5's, you have served well.
6FC58AF0-BE3E-4883-9D71-4C7446E8B6E9_zps
DC56A2FD-73F1-42C2-BF79-9531B5C09193_zps
6 boost twin scroll manifold. 38 mm Tial gates will be used. Still waiting on those guys.
5D98E713-AF0A-4548-9A7F-5E68575D186C_zps
In light of this fuel issue, I've gone mega overkill. Ordered three of these Fuelab filters. A single 75 micron filter pre surge tank with twin 6 micron filters post pump. I'm going to "Y" it and run the filters in parallel seeing that the filtration is so fine. A set of stainless steel internal 1700's will be going in instead of the 2000's.
BE2D7105-7F7B-4657-AC97-8C726ABED4CB_zps
EFR speed sensor. It will be Intersting to see what speeds the snail is spinning.
4EE0D946-02F2-4A3A-8D64-9EF016CCB2B9_zps
1B01DFC0-5BF8-4716-838B-89DBA1D985BA_zps
Display for the sensor.
Holley Dominator 1800 fuel pump has been purchased and getting rid of these 044's. A new stainless surge tank will be made and will live in the boot.
All intake, exhaust, surge tank fabrication will be done by Mick_O.
Some Nismo diff bushes have been bought also. I have solid alloy ones in there ATM and they're bloody horrible.
A catch can has to be made for the OS88. It just spews oil out of the breather when giving it some on left hand corners. Poor form OS!!!
  • Like 2
The secrets out the bag now big dawg EFR FTW!!! Really can't wait to finish that EFR setup on that shitbox evo of mine and get into this thing :)
Edited by Mick_o
  • Like 1
So you are having issues with corn juice and file system, so you decide to change turbo package. Don't you like driving this thing?
How long does a turbo swap take? It's not the end of the world.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
