I'm from Brisbane Qld, sorry for the question as I haven't read my os giken booklet. But once you engage reverse by pulling the lever up do you have to put the lever up again to go back to neutral or do you just push the lever down as you would when engage the next gears?
From reverse you still have to hold up to neutral. From neutral you just pull back for first.
It definitely changes the car from the tall geared OS 5 speed that I had in it. "Woke it up" as such.
You don't need to run the OS clutches, but it takes out one less headache when putting it all together. I looked into trying to salvage the coppermix as they really are THE clutch to have in a road going GTR. (Mine was in there since 2005 with no service/rebuild at all). It was all too hard. For starters the coppermix was a pull type, this box only has the bosses for a push type, then there was the bigger input shaft issue. The R3C is awesome, much better than expected and NOT how I remember the R3C in other cars I've driven. The pickup/friction point is quite low compared to the Coppermix which takes a bit of time to get used to. Apparently this is the new type. What they have changed, I'm not sure.
You will need to supply your own transfer case.
There are 4 gear options available. I went option 2. Assuming a 265/35x18 tyre and spinning to 8000 rpm each gear will go to
82
118
160
200
234 (same as stock as its 1:1)
310 (same as a factory 5 speed as its 0.757)
You're basically slotting an extra gear in before the 4th gear in a factory 5 speed box. If that makes sense.
With the box, I bought;
Box itself
Modified cross member
Bent shifter
Clutch
Release bearing
Clutch aligning tool
There is a bit of crashing and banging at low rpm, but that's just me not getting the timing 100%. I've only driven 60 kms or so with it so still very much a noob. Up high and drive it like its stolen, smooth as silk. Just slides into the next gear, you don't feel anything through the shifter. As quickly as you can pull back on the gear stick its in. I've found preloading the stick before you lift seems to work well too. I'm still clutching in ATM but as time goes on I'm sure I'll be able to do the no clutch/ lift throttle technique. I'm obviously not tuning a strain gauge - yet. I wouldn't like to daily drive it but for a weekend car it's great!
Thanks a ton. This post will help a lot of other crazy people like us!
Marcus!
It will happen, just a case of when.
Have you changed your number? I rang you a few weeks ago.
Got a gold mine lease so away a lot digging holes, blowing crap up.
Give us a tingle when you get the chance, boss.
Will do champ..bit crazy at the mo but asap.
Lol that's awesome Marcus! Just gotta try stay sober now
Why ?? Alcohol and explosives.. what more can you ask for ..cracker night on steroids !! :cheers: :cheers: :cheers: :cheers:
  • Like 1
  • 1 month later...
Have been a little quiet here lately. This fuel gunk issue has really given me the shits. The baskets in the injectors kept filling up so in the end I decided to rip them out for the journey to Richmond where the next round of goodies are going on.
20220004-9318-4519-BA51-1EA194886659_zps
37834A2D-20B0-4E50-8D5D-E1F834E6C988_zps
BA2A1B01-BBB6-4181-AC44-442F28C6499A_zps
EFR 8374 1.05 ass end. See you later -5's, you have served well.
6FC58AF0-BE3E-4883-9D71-4C7446E8B6E9_zps
DC56A2FD-73F1-42C2-BF79-9531B5C09193_zps
6 boost twin scroll manifold. 38 mm Tial gates will be used. Still waiting on those guys.
5D98E713-AF0A-4548-9A7F-5E68575D186C_zps
In light of this fuel issue, I've gone mega overkill. Ordered three of these Fuelab filters. A single 75 micron filter pre surge tank with twin 6 micron filters post pump. I'm going to "Y" it and run the filters in parallel seeing that the filtration is so fine. A set of stainless steel internal 1700's will be going in instead of the 2000's.
BE2D7105-7F7B-4657-AC97-8C726ABED4CB_zps
EFR speed sensor. It will be Intersting to see what speeds the snail is spinning.
4EE0D946-02F2-4A3A-8D64-9EF016CCB2B9_zps
1B01DFC0-5BF8-4716-838B-89DBA1D985BA_zps
Display for the sensor.
Holley Dominator 1800 fuel pump has been purchased and getting rid of these 044's. A new stainless surge tank will be made and will live in the boot.
All intake, exhaust, surge tank fabrication will be done by Mick_O.
Some Nismo diff bushes have been bought also. I have solid alloy ones in there ATM and they're bloody horrible.
A catch can has to be made for the OS88. It just spews oil out of the breather when giving it some on left hand corners. Poor form OS!!!
  • Like 2
The secrets out the bag now big dawg EFR FTW!!! Really can't wait to finish that EFR setup on that shitbox evo of mine and get into this thing :)
Edited by Mick_o
  • Like 1
So you are having issues with corn juice and file system, so you decide to change turbo package. Don't you like driving this thing?
How long does a turbo swap take? It's not the end of the world.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
