running yet or you doing a bobby on us
cut bobby some slack ... he is doing what's never been done before & is following the laws of joule thomson effects....
apparently his tune is gonna be f1 spec which is why its taking so long :laugh:
Hopefully goes to Hypertune tomorrow for turbo to plenum piping but I've heard that before!
Yeah yeah, turns out the rear turbo was cactus anyway. 5000 kms. Spose they didn't like to be run so hard so either way the turbos were coming off. Oil all through the dump.
Have you forgot already that you actually removed that one thing that may we'll have saved your rear turbo from leaking oil.
It's actually very critical that you don't oversupply oil pressure to the cartridge on ball bearing turbos when running a high volume oil pump.
I actually recall you saying you had the HKS .8mm restrictor years ago, but you ran the 1.2mm one with your big oil pump.
The result is that you expired a turbo very quickly from over pressurising your ball bearing cartridge with oil pressure which was meant to be drip-fed.
Common issue when running a larger oil pump.
Not really the Turbo's fault[emoji19]
  • 5 weeks later...
Finally, an update.
Car was dropped off at Hypertune on Friday for the cooler mount up, turbo to plenum piping and a few other bits and bobs.
467E9FC8-0299-4D4C-B14E-AE25799E6C0A_zps
Sneak peak at what they do to guide the air into the runners. Core measures 680 x 325 x 100.
F6DEF3DD-3615-41F0-ABA7-BBBA2E8FCC63_zps
Cooler mounted up.
B921CC5F-5126-4D00-BD4A-364335966E60_zps
I'll have a few more photo's on pick up.
  • Like 3
What are u doing with the BOVs
All the factory stuff got ripped out. The EFR has one on the compressor housing. I bought the Turbosmart kompact EFR version. Directs the pressurised air back at the comp wheel.
Clean, neat, simple.
It's not shown in those photos because Hypertune pulled it off to weld the 90 on the comp housing.
  • Like 1
B5D6E3A6-64B0-4D57-8CE0-4C7C240EBC14_zps
1BB8CCA0-082C-45A8-93CD-AAAFD37FAC64_zps
AD0EDA6B-3C9C-4086-BAAD-1F6467AE303B_zps
425FB7A9-F51C-4BB3-A062-AE4C8376A4B7_zps
38100F92-DE3D-429E-AD72-E7BE66DAFB2B_zps
Few pics from today. They put a bung for an aftermarket air temp sensor just before it pops back into the engine bay. Do away with the "engine bay sensor" on the plenum. Pipes from snail to the guard and guard to plenum will be black. No clamp on the plenum, it would have meant it had to be removed, no thanks!
I can imagine!!
Pipework looks awesome!!! Wiggins clamps?
Yeah, Wiggins. 5 in total. Blown cooler pipes are no longer (unless the plenum one pops). No more taking front bars off!
Thinking about painting the airbox black, cutting a hole in the top of it and using the factory airbox snorkel to feed the box too. Can't hurt!?
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
