For anyone else playing along re timing issue.
A good unbiased thread here.
Unsurprisingly issues occurs on a number of ECUs, not limited to Haltech, and even features our OP(and others) claiming the same issue on a PowerFC, madness...
Seems like most ECU manufacturers and Tuners were aware of and had produces solutions to address it, including modified/better CAS discs, crank triggers, etc.
Too much was said for me to not look into it as a precaution - So thanks for that even if your caps are flat.
I am probably as far from a flat clapper as you can get!
Yes it is an issue with not just Haltech, motec m800 and earlier, link etc all suffer from it.
With a good CAS and good signal wires PFC, Nistune and Adaptronic won't suffer from it, if you get really bored you can listen to a youtube video or post Andy from Adaptronic made about it too. So for a plug in ECU designed for that engine I think it's a rubbish ECU choice if you need to fit aftermarket sensors.
It's always to learn something new :D
Haltech "claim" not an issue with Platinum Pro, but was a problem on earlier ECUs, guess I'll find out it ever happens.
So I guess the bombshell here is old shit can be problematic... but new shit has less issues.. Who knew!
LOL it's defiantly a problem with the Platinum pro, even worse with the Elite range but I won't tag Jono Pace in this thread for him to rage about them.
Don't always believe the marking bullshit that comes from a manufacturer, i am sure you tuner would have tuned you car extremely safe up top if it was showing any issues.
Just now, ActionDan said:
He might have given me an ear bashing on FB about it already?
Wonder why my car hasn't seen it. Maybe the key is don't drive it.
it may well have it, you can tune around it to a degree or just ignore it like most do.
That must be it then, I can't there being any possibility that it's just working properly.
I'll be ready to replace the ECU when I put my TH400 in.
Just put a crank trigger kit on it!
You will need it for the 1000hp and your TH400
  • Like 1
Setup a real crank trigger.
Throw OEM CAS disc in the bin. Fit an aftermarket disc.
Run whatever ECU you want or as many Haltech products as your passenger footwell can fit. Job done.
  • Like 2
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
