  • Replies 89
Love this pic Alex!
Sorry I missed it - looks like you all had fun.
That's my favorite pic of my gtr, my mates gtr and the awesome r35 gtr !!
Thanks guys, the Mrs was snapping away inbetween bumps! What happened before that was slightly butt clenching up the hill with the coaster bus. Lets just say performance gap between R32 GTR and R35 was displayed in front of me. Provided the lulz looking back on it.
Go another of the R35 on a seemingly empty road- one of my favs.
Me neither.
By the way, it was nice to meet you on the side of the road in the middle of nowhere Brodie. :)
Well run cruise guys, as usual. It's always fun to tag along with the Skyline Club.
haha you 2 man
Had a great time yesterday, meet a few more stagea owners and good to see some familiar faces again :)
here are a few pic's i took https://www.facebook.com/media/set/?set=a.293216754091850.69150.192043784209148&type=1&l=52dcba9518
Nice shots there Alex. Are those through the windscreen? Suprisingly no glare if they are. Kudos to your Mrs!
Yeah they are Eric, I'll pass it on. And just a old Canon point and shoot- bout $120 worth! Goes to show sometimes it doesn't matter what you got- its what in the pic that counts! :P
Awesome Day, one of the best cruises I have been on.
I would have loaded more pics but I hit my upload limit for the month. Link is below:
http://www.flickr.co...s/77653397@N06/
heh, thanks for the photos.. I didn't go home .. i just kept driving up through the vineyards :cheers:
Great cruise! First time on putty rd, was loving sitting behind your car, it looked awesome when it took off! Good to see a 35 being driven as nissan intended!
Thanks for the Photos!
The look great and yes my engine before had the oil restrictor blocked by some junk and seized oil to the head.
Was an awesome day all round.. Keen to see some more pics, I was going to get some at the end point but by the time I had finished lunch everyone was pretty much taking off... The only pics i got was of mine just after the bike crash waiting everyone to come back through ha..
I only took a few pics as well. I hope some of you also took the opportunity to take some pictures of your pride & joy while in the Hunter too. Lots of great back drop scenery.
Love the first one 'the hot chick' need to facestalk and find her :P
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
