I just got a clutch from KB clutches in Sydney.
He was a really nice bloke that asked everything to do with the car and the power/rpm/use
Managed to pick something up for $410 including postage to ACT
Only time will tell if it holds up or not.
But I currently am pushing around 240-250rwkw
I know this is an old thread but i did a quick search and didnt find what i was looking for, what is the Exedy cushioned Button 34GTT clutch rated too power wise? I think it was 330rwkw from memory, but if somebody has a better indication please let me know as i will probably let the guys know before they tune it ;)
I'm hoping my cushioned button holds up, should do for a while as it hasnt done a huge amount of work..... Just not sure of what its rated too?
Next clutch for mine will be the JB i think as i was told they are good to drive :D
Softer than stock pedal, no shudder, holds massive power.
Hmmmm mine definately shudders which is sent down my drive train to my diff. Subsequently, the backlash in the diff is sloppy as and all I hear is loud thuds if you sit on the clutch longer than a second. Clutch has done about 3-4000km's since new. Flywheel was machined by JB aswell. I thought it might be just a wearing in issue, but it would seem its not!
Also, how does yours take up/grip? I've found mine goes from OFF to ON in a VERY small range of movement...
Edited by R32Abuser
That can't be right surely?
It's a single plate clutch. Can get the same thing from NPC with brand new parts instead of the JB second hand ones. NPC are only about $750-$800
Ive seen people quote like $1300 odd on here.
If it was 2k then I would not even consider him and just go straight for a nismo coppermix! or if you dont have the coin then get a NPC clutch.
The shuddering might be caused by the cracks in the second hand pressure plate
got mine for about $1000
4100 lbs of clamping force. Plenty of clamp for my application - if anything its WAYYYYY overkill considering its a street car.
Elite/Daniel, surely JB would have seen this? This has happened from day one, and he said that it would initially shudder but would come good after 1000km's.
They go for about $1200 depends on what you get. The shudder could be from contamination, oil and crap getting on the flywheel makes it glaze, hence shudder.
Yeh my clutch has a small friction point, 100kms of driving and you get used to it.
Just for reference, the pricing on the GTT was quite a lot more than a GTST as they are the pull time clutch etc..... My Exedy was around $1300 at trade price at the time i got it (They have probably come down a lot now) but the 34 clutches were quite expensive..... Just like EVERYTHING else on the damn things that is slightly different to the other models :glare:
If your poor ten obviously your going to go for the cheapest option
Well surprisingly the 33gtr has the same clutch as you *gasp*!
Npc sprung button clutch capable of supporting up to 650hp
$750.
/thread
$750.
/thread
Wow, i said "pull time" that sounds pretty dodgy :P
Ill definitely be looking at other options when it comes to the next clutch choice... SO FAR the cushioned button has been good, so hopefully it holds up.
To the OP, shop around as it seems there is plenty of options around ;)
Hey guys,
Sorry been so busy with work and getting my car sorted etc.
I ended up going the NPC Heavy duty Organic clutch, Rated to around 300rwkw this is plenty for what im going to use it for.
i got it all installed and parts (Inc Flywheel machining) And my coils changed while he was there, 4L of Redline lightweight shockproof for a grand total of $1360 (Inc clutch, labor, oils, maching of flywheel) Not bad if you ask me, im pretty happy with how i did, Now for fuel pump on the weekend, and then off to powertune on monday!
POWAHHHHHHHHHH!
Thanks to everyone who dropped their 2 cents worth, it was worth alot more to me :D
<3 SAU
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
