I use mine every 3rd night? not too bad. I just drop it at around 1700rpm, I don't bother driving it smooth (clutch will last longer). Up the car park ramp at my gym is gold, there's a speed hump midway up. I usually just handbrake then chirp it over, people think I am retarded.
Because race car :P
Sweet, thanks guys! More parts i didnt budget for...... Car has done 1500kms since tune and has killed coilovers and clutch so far, what next? (Nobody answer that, Flamin Mongrels) lol
done a few thousand on my Carbotic now Mat..2 track days..
Its no pig its a dream to drive man, you won't be disappointed at all
unless you prefer grumpy old man clutches...why anyone would want one or one of those crappy rattly metal things is beyond me.
.The NPC is all class
Its a dream to drive man you won't be disappointed at all
.The NPC is all class :D
Ah sweet! Thanks for that :D
Has it still got a good pedal feel etc? Apparently he said mine will be modified as ill aim for 400kw eventually.... :yes:
I slip my 10' NPC every time I take off, I know its not the best for the clutch but I'm 2 years in and its still showing no signs of slipping.
There a quality product thats for sure. I'll have a look at mine when the engine comes out of my car in the last half of this year.
Can always send it back for a rebuild anyway
I also did some calling around apparently confusing ppl when i called after matt had lol .... but i have the silver plated excedy comp clutch abd jim berry said its a good bit of gear and he can build it to handle 450kw + with a 10" or bigger something and solid centre carbon thingo ?? sounds good he built my mates cusco hyper angle and its amazing and handles all the clutch kicking he can thor at it withh 300 odd kw so might go down that path
LOL, i spoke to Jim for nearly 2 hours yesterday man!
He said they will be a pretty tough bit of gear, mine will be different specs to yours though as ill be on the road more than track :P
I got that Exedy Silver NC10T push pressure plate from a R32 GT-R if you want it, it's 1.1 tonnes
Problem is your GT-t is Pull not Push, unless you want to convert it to a push setup. Cheaper in the end.
  • 1 year later...
#strongbump
So yeah, I've had my NPC clutch for nearly 2 years, about 15 000 km & 3 track days..
It's starting to slip!
In 4th when you mash the pedal it will slip a little/shudder then bite & my friction point is quite high up. It engages in the last 1cm or so.
I think it's dead, maybe my mates have ridden it to death :(
How long has your NPC carbotic lasted?
I pulled my NPC when I did my engine change out. decided to get it rebuilt rather then having to pull the gearbox out later on if it started slipping. Have to say, the clutch looked great, no marks/hot spots etc on the flywheel or pressure plate and the friction material, besides being worn, looked great. Best looking clutch I've ever pulled out of a car. Could have gone back in but was running low on friction material so thought I'd start fresh
They were very helpful and quick rebuilding the clutch to. Sent it away Thursday I think, had it back on Tuesday or wednesday.
#strongbump
Mine should have been similar in design i guess and after 5000km it also looked brand new... I would go with Callans suggestion and just get a freshen up, its just new pads and a quick clean up most likely... Could be other causes for the premature wear though not necessarily the clutch itself, grease or oil contaminating it etc... Only way to know is to pull it out and have a squizz!
I ran 255rwkw for pretty much the whole time I had the clutch in, and I daily drive it and slip it on the street a fair bit. So I'd say if the wear on mine was excessive then it was to be expected. I dont think it was terribly worn but, should have measured how much material was left and compared to new.
The rebuild is basically a complete new clutch. The pressure plate I think was brand new and they just removed and replaced the pads on the clutch plate, must have checked the springs etc and the spline as well but this wasnt replaced (all looked good when I pulled it out so not suprised)
All up it cost me just shy of $500 with a new throwout bearing and express delivery, so while thats not 'cheap' its not to bad for a new clutch considering new ones are up near $800 now I think?
This is all my NPC gear reconditioned:
Edited by 89CAL
I'm just a little concerned about the premature wear, especially my car isn't make more than 200kW
Might pull out the box next weekend whilst I fit the new turbo :)
Yep good plan! There is no way its power related and it shouldnt wear that quick unless its been driven like shit...
Pull it out and report your findings :P
#strongbump
Just copper mix it and be done with it. If you did it in the first place you would have to pull the box out again! :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
