I use mine every 3rd night? not too bad. I just drop it at around 1700rpm, I don't bother driving it smooth (clutch will last longer). Up the car park ramp at my gym is gold, there's a speed hump midway up. I usually just handbrake then chirp it over, people think I am retarded.
Because race car :P
Sweet, thanks guys! More parts i didnt budget for...... Car has done 1500kms since tune and has killed coilovers and clutch so far, what next? (Nobody answer that, Flamin Mongrels) lol
done a few thousand on my Carbotic now Mat..2 track days..
Its no pig its a dream to drive man, you won't be disappointed at all
unless you prefer grumpy old man clutches...why anyone would want one or one of those crappy rattly metal things is beyond me.
.The NPC is all class
Its a dream to drive man you won't be disappointed at all
.The NPC is all class :D
Ah sweet! Thanks for that :D
Has it still got a good pedal feel etc? Apparently he said mine will be modified as ill aim for 400kw eventually.... :yes:
I slip my 10' NPC every time I take off, I know its not the best for the clutch but I'm 2 years in and its still showing no signs of slipping.
There a quality product thats for sure. I'll have a look at mine when the engine comes out of my car in the last half of this year.
Can always send it back for a rebuild anyway
I also did some calling around apparently confusing ppl when i called after matt had lol .... but i have the silver plated excedy comp clutch abd jim berry said its a good bit of gear and he can build it to handle 450kw + with a 10" or bigger something and solid centre carbon thingo ?? sounds good he built my mates cusco hyper angle and its amazing and handles all the clutch kicking he can thor at it withh 300 odd kw so might go down that path
LOL, i spoke to Jim for nearly 2 hours yesterday man!
He said they will be a pretty tough bit of gear, mine will be different specs to yours though as ill be on the road more than track :P
I got that Exedy Silver NC10T push pressure plate from a R32 GT-R if you want it, it's 1.1 tonnes
Problem is your GT-t is Pull not Push, unless you want to convert it to a push setup. Cheaper in the end.
  • 1 year later...
#strongbump
So yeah, I've had my NPC clutch for nearly 2 years, about 15 000 km & 3 track days..
It's starting to slip!
In 4th when you mash the pedal it will slip a little/shudder then bite & my friction point is quite high up. It engages in the last 1cm or so.
I think it's dead, maybe my mates have ridden it to death :(
How long has your NPC carbotic lasted?
I pulled my NPC when I did my engine change out. decided to get it rebuilt rather then having to pull the gearbox out later on if it started slipping. Have to say, the clutch looked great, no marks/hot spots etc on the flywheel or pressure plate and the friction material, besides being worn, looked great. Best looking clutch I've ever pulled out of a car. Could have gone back in but was running low on friction material so thought I'd start fresh
They were very helpful and quick rebuilding the clutch to. Sent it away Thursday I think, had it back on Tuesday or wednesday.
#strongbump
Mine should have been similar in design i guess and after 5000km it also looked brand new... I would go with Callans suggestion and just get a freshen up, its just new pads and a quick clean up most likely... Could be other causes for the premature wear though not necessarily the clutch itself, grease or oil contaminating it etc... Only way to know is to pull it out and have a squizz!
I ran 255rwkw for pretty much the whole time I had the clutch in, and I daily drive it and slip it on the street a fair bit. So I'd say if the wear on mine was excessive then it was to be expected. I dont think it was terribly worn but, should have measured how much material was left and compared to new.
The rebuild is basically a complete new clutch. The pressure plate I think was brand new and they just removed and replaced the pads on the clutch plate, must have checked the springs etc and the spline as well but this wasnt replaced (all looked good when I pulled it out so not suprised)
All up it cost me just shy of $500 with a new throwout bearing and express delivery, so while thats not 'cheap' its not to bad for a new clutch considering new ones are up near $800 now I think?
This is all my NPC gear reconditioned:
Edited by 89CAL
I'm just a little concerned about the premature wear, especially my car isn't make more than 200kW
Might pull out the box next weekend whilst I fit the new turbo :)
Yep good plan! There is no way its power related and it shouldnt wear that quick unless its been driven like shit...
Pull it out and report your findings :P
#strongbump
Just copper mix it and be done with it. If you did it in the first place you would have to pull the box out again! :P
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
