I've seen alot of 350z and G35 owners and others do the VK56 swap and it's a great engine. My question is can you swap a VK56 into an R34 without replacing the transmission. I don't mean can it handle the power and torque, I mean can the gearbox actually bolt up to the engine. It would be amazing if the VK56 can bolt up to an R34 GT-R and keep the AWD while having the VK56. So what do you think guys can this be done...?
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/
I asked Robbie Ward if a VK56 would fit in a skyline and he said that it would be to wide and wont fit easily in GTR engine bay. He has one for his new rail car and said these are massive compared to a LS1
Edited by WHITER33GTS-T
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-6333488
yh haha I think I underthought this idea haha if anyone can do it Robbie can. I just thought it was a good idea since I've seen these engines being thrown at everything and they're good engines. i think the front diff thing would pretty much kill this idea would it not?
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-6334200
Anything you aim to do with 2.6lt can be more easily achieved, be more reliable, and will be less stressed overall when its done with more displacement.
Just just think how much fun a twin turbo VK56 would be.... or stoke it to 6lt first :yes:
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-6334493
Not for the money.
Spend $30k shoehorning a VK56 into a GTR and you'll have a bog stock VK56 in a GTR. Spend $30k building up an RB26 and you'll smash the living shit out of your stock VK56 engined R34.
Not to mention the aftermarket support for RBs is probably 100 times larger than that of a VK. Sure, when money is no object, go nutso. I'd do some crazy conversions if I had millions, but just because you can, doesn't mean you should.
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-6334532
  • 1 year later...
Vk56 at its widest point is 26.5"
these only came out with an auto behind them
There is also the reluctor wheel mounted to the flex plate
there is an adapter plate and clutch kit available off the shelf to match a 370z manual
there is also the height, custom manifold defiantly will be needed
there is also the sump which holds oil vertically at the rear of motor, instead of the horizontal like the RBs (this was to fit the front diff in front of it so it would fit in the Nissan titans
On top of that, not much room for the turbos
they also came out at 9.8:1 (some with corn based eflex)
2007+ = cvct
timing chain also has been known to jump at high revs
US guys claim 17mile/gallon with their n/a
Ecu? 370z use same computer
pistons Google gtm
cams Google Jim wolf technology (s2/s7 s2vct s8 or s8vct most popular
(costs
2k long motor
1k 370z box
1,200 adapter plate
1,200 flywheel/ clutch kit
1,500 cams
300 springs
2-3k importing costs
1,200 pistons
6k stillen supercharger kit
then once here 5k+ fabrication
End result probably around 450-500hp
edit;
Just noticed the dates, sorry for mega post bump lol
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-6904839
  • 2 years later...
Mega bump and my first post in maybe 5 years but yeah Robbie Ward is right, they are wide as hell being twin cam and all, but they do fit. Google Ian Fournier.
I've got a high comp atmo VK56 in my R32 sedan drift build.
The tightest part was the clearance between the strut towers and the exhaust ports.
Ended up putting in an S14 steering rack for better clearance and getting a custom steering column made to change the angle on the universal to give more room.
Also ditched the brake and clutch masters, running a floor mounted pedal box with remote reservoirs instead. That part isn't essential but I wanted to mount the engine as far back in the engine bay as possible cos racecar.
Custom tunnel etc. Got photos if anyone's curious.
Putting one in an R34 would be fairly similar I would imagine, but forget AWD, if you wanna go big get one of robbies 4wd RB30 long blocks. Be way cheaper in the long run.
Edited by Hillstc
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-7727481
Needs more power though - 330AWKW is just a rough and ready RB30 or a mildly modified RB26.
Not saying you're wrong, but it is daily driven on unopened motor with fuel supply issues. and an 80's Jap V8 engine to boot.
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-7727825
I'm not saying 330 awkw is not a decent lot of power but it just seems (in my opinion) a barely adequate return for the huge amount of time and money that has gone into this (well executed) project. And of course it needs a better fuel supply. The owners seem happy with it and that's fine.
https://www.sau.com.au/forums/topic/398723-vk56-r34-gt-r/#findComment-7727929
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
