took my car for a drive tonight after i changed coil packs, my missfire was so close to being fixed just a little tiny missfire, anyway i turned the car off and looked under the bonnet, i could hear a noise which was coming from the coil pack/injector reigion (top of engine) like a crackle???? or a crinch if you will.....it sounded like the injector was clogged or still pulsing even tohugh the car was off???
is this normal? or is this even the problem? i dont know where the noise came from exactly, but it was every 2 seconds and constant....
https://www.sau.com.au/forums/topic/398948-wtf-is-this-weird-noise/
The midget with the milo tin is normal, its just metal components losing heat and cooling down. The other sound is a strange sound, if I had to take a wild guess I'd say some sort of liquid dripping onto something hot and evapourating.
If there was air escaping from a pressurised cylinder, it should be more consistant.
That is a really odd sound, it doesn't sound electrical, mechanical, metallic.
I have this sound! Its air bubbles in a coolant hose somewhere. From your turbo or heater probably like mine. Im still not sure what is rooted though ha ha but been driving it for a few weeks and nothing hapened yet. Maybe a slightly rooted Head gasket ? :unsure:
Use a wooden dowel between 30-60cm long approx > one end in your ear + the other placed on various parts of the block > sound becomes crystal clear when in close proximity.
(Using a long screwdriver is a bit less accurate)
well I'll be damned!
ive had the car for half a year now and it only done it the first time the other night, hasnt happened prior or since the other night, it was 1 one off??
i was flogging the car that night, got it to 180Klms, and when i turned it off that sound happened, so could me flogging it have something to do with it??
Do not replace the headgasket until some diagnostic tests prove that is an issue.
See if it does it again ever, but otherwise i would say its just the turbo and metal exhaust components cooling down as sarge suggested
It doesn't sound like bubbles to me, how did you come to that conclusion?? Genuinely interested, not being a jerk.
Edited by Hanaldo
Well the on a turbo hose you put your hand on it (with a rag obviously) and you can feel it sort of vibrating as the bubbles are going past.
Also when radiator cap is opened while the noise is happening it will spit and fart at you. However it is almost as though the water is boiling as it does not use any water or over heat.
Been driving it for over 5000km like this now and nothing has happened yet.
Edited by ANT_32
That sounds like something boiling for sure, theres a restriction which opens at a certain pressure and it builds up then lets go repeatedly.
If thats the case it should gradually slow down as the engine cools.
Ive heard that sound somewhere before, cant remember.
Well I'm guessing there is a blockage in the turbo line then. So when the motor is turned off and has no flow the coolant in the turbo boils.
Been studying a bit and found coolant boils at about 240 ish degrees give or take with pressure etc.
Turbos get hotter than that.
So it would be possible especially if you was giving it heaps before turning off I reckon.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
