Selling a bunch of r32 stuff for cheap as have decided to keep my skyline might aswell sell the stuff I'm not gunna use :)
http://www.skylinesaustralia.com/forums/topic/399965-r32-parts-and-several-sets-of-rims/page__pid__6353582#entry6353582
Gday Folks, got some spares from a second 33 i owned which i blew up a motor on.
HKS Turbo Timer - $20
Turbosmart BOV - $20
Central Locking Module - $5
Climate Control Units x 2 - $30 each
Silver Dash Surround - $10
Series 1 GTR Headlights (will fit GTST) - $200
Standard Intake pipe and Throttle Body - $40
Dash Cluster with Automatic Gear selectors - $20
Ignition Coils (with Harness) - $250
Alpine Head unit - $50
Kenwood Amp - $75
Turbosmart Boost controller - $15
Autometer Boost Gauge - $30
Intercooler piping - $40
Standard Airbox - $40
PWR intercooler - $75
Both Front seats - $100 each
Rear Seats - $40
RH Door trim - $5
Rear inside quarter trims - $5 each
3" cat back exhaust with cannon - $300
20" Advanti Rims (need Tires) - $500
Or make an offer on anything.
Message 0411166390 or PM for details
Pics to come when i get my camera back
Josh
hey guys...
i have a heap of odds and ends from a S1 R33 that i wrote off..
unfortunately mainly interior plastics and some switches guages etc..
also have 2x dashpads
boot lid (that darkblue/green colour)
and possibly a couple of other things like carpet and roof liner (for sunroof).
i also have 3 17" multi fit crome mags off of a pulsar.. they've also been on an exa and a mx5.. probably only good for a trailer or for the rubber which is maybe 50%.. best to inspect first. $150
i'll try and organise a more comprehensive list with prices. and if i can, pics.
until then PM me or give me a call on 0402945546 and enquire and or make some offers..
cheers..
Hey all need to sell my commodore wagon
Looking for $1000 willing to negotiate currently painted matte black has roughly 301xxx ks on it selling cause I need something that will tow my skyline with more ease auto runs fine always starts first go will post thread and pics tonight in for sale section
Hi all,
I have a 1994 R33 four door skyline up for sale.
It has been mildly modified with a front mount intercooler, after market fuel pump, cold air intake, aftermarket exhaust, turbo timer, upgraded ecu. It runs 16psi and has 270 at the wheels.
It's metallic grey with 18inch rims and has 129000 genuine kilometers on the clock.
It's a 5 speed Manuel with a clarion touch screen DVD player, Rockford fogs ate amp fusion sub, six inch splits in the front and rear, dark tinted windows, sports steering wheel and a top of the range alarm system. It's road legal and just passed it's rego inspection. The car is registered till July 2012.
The car is in excellent condition first to see will buy.
Asking $10000 for it but willing to negotiate.
Feel free to contact me on 0424525951 or email me on [email protected]
Sorry I have no pics at the moment.
Hi Kasko,
Sorry mate not sure about the turbo and injectors that are on it. The previous owner did a bunch of stuff to it and had a list of what has been done but ive lost it so I just mentioned the stuff that I can remember. Also forgot to mention I just spent 2300 on bilstien suspension and bushings so it sits nice and rides very well.
Thanks
Mattyb
r34 front+dump bellmouth stainless pipe <5000km (approx) suit R34 GTT Coupe $150 + you free O2 sensor
r34 GTT turbo <100,000k kms never boost controlled with extra boosts and always turbo timed, no issues no noises 250$
r34 GTT stock intercooler 20$
R34 GTT Coupe rear stock shocks good condition <100,000k kms (pic is front but i have backs) 50$ each
R34 GTT Coupe stock exhaust to catback Someone please take :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
