Stock Stagea turbo dump pipe... unsure if it will fit the R33/34.. I think R33? may need to be confirmed
$20
..and still selling the stuff in my sig.
Edited by S T A R 3 3
For sale:
Standard RB20 Turbo - reasonable condition, some shaft play but still usable $50
T04e dump pipe flange + gasket (suit eBay turbo KLS Power Spirit, maybe others) $25
S13 front hubs, appear to be good condition, missing 4 wheel studs $40
Monza catch can, 1 litre, comes with fittings and hose brand new $30
Hey Guys.
Selling a few bars I have lying around
The top bar is a R34 Nismo S Type rear bar ready for paint
and the bottom bar is a R32 GTR front bar to fit a GTS-T also ready for paint.
$400 each ONO!
PM or SMS only to 0404543040
Thanks Bren
hey guys looking to sell my vp commodore wagon again sold it too a mate who then lost his license so i got it back, will only take a little bit to get roadworthy
needs two new front left wheel studs, rear view mirror bolted back on, could use a service and the wheels on it need new rubber
has roughly 317xxx ks on it is an auto and has been sprayed black
only looking for $400 (with the 18 inch chromes)
or $300 without (but you will need to bring your own wheels)
car is currently unregistered
i can be contacted on 0425416020 or [email protected]
cheers
hey guys i got some body kit for sale.
R33 GTR style front bumper (new) $350
R33 Side skirts $200 (used, black in colour in every good condition was on my car i pulled it out)
FMIC $100
O42l545387 Shiv
make me offer need them gone
Hi Guys,
Cleaning out my garage and I have found a heap of stuff I no longer require from old projects that changed direction
Brand New Parts still in boxes.
NISMO SR20DET Thermostat (21200-RS520) - $70
NISMO Big Operating Clutch Cylinder (30620-RSR40) - $140
GReddy Adjustable Camshaft Gear Sprocket (13523306) - $140
Please PM me if your interested in any of these parts
Edited by naughtyruski
The nismo clutch cylinder will also suit
  • Nissan Skyline BNR32 GTR (RB26DETT, 08/1989 - 01/1995) (Notes: 02/1993 - On, Pull Type)
  • Nissan Skyline BCNR33 GTR (RB26DETT, 01/1995 - 05/1998)
  • Nissan Skyline BNR34 GTR (RB26DETT, 01/1999 - 08/2002)
  • Nissan Stagea WGNC34 RS-Four (Series 1) (RB25DET, 09/1996 - 08/1998)
  • Nissan Stagea WGC34 RS-V (RB25DET Neo 6, 08/1998 - 10/2001)
  • Nissan Stagea WGNC34 RS-Four (Series 2) (RB25DET Neo 6, 08/1998 - 10/2001)
  • Nissan Stagea WGNC34 260RS (RB26DETT, 11/1997 - 10/2001)
Great for heavy duty clutches (larger bore)
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
