Stock Stagea turbo dump pipe... unsure if it will fit the R33/34.. I think R33? may need to be confirmed
$20
..and still selling the stuff in my sig.
Edited by S T A R 3 3
For sale:
Standard RB20 Turbo - reasonable condition, some shaft play but still usable $50
T04e dump pipe flange + gasket (suit eBay turbo KLS Power Spirit, maybe others) $25
S13 front hubs, appear to be good condition, missing 4 wheel studs $40
Monza catch can, 1 litre, comes with fittings and hose brand new $30
Hey Guys.
Selling a few bars I have lying around
The top bar is a R34 Nismo S Type rear bar ready for paint
and the bottom bar is a R32 GTR front bar to fit a GTS-T also ready for paint.
$400 each ONO!
PM or SMS only to 0404543040
Thanks Bren
hey guys looking to sell my vp commodore wagon again sold it too a mate who then lost his license so i got it back, will only take a little bit to get roadworthy
needs two new front left wheel studs, rear view mirror bolted back on, could use a service and the wheels on it need new rubber
has roughly 317xxx ks on it is an auto and has been sprayed black
only looking for $400 (with the 18 inch chromes)
or $300 without (but you will need to bring your own wheels)
car is currently unregistered
i can be contacted on 0425416020 or [email protected]
cheers
hey guys i got some body kit for sale.
R33 GTR style front bumper (new) $350
R33 Side skirts $200 (used, black in colour in every good condition was on my car i pulled it out)
FMIC $100
O42l545387 Shiv
make me offer need them gone
Hi Guys,
Cleaning out my garage and I have found a heap of stuff I no longer require from old projects that changed direction
Brand New Parts still in boxes.
NISMO SR20DET Thermostat (21200-RS520) - $70
NISMO Big Operating Clutch Cylinder (30620-RSR40) - $140
GReddy Adjustable Camshaft Gear Sprocket (13523306) - $140
Please PM me if your interested in any of these parts
Edited by naughtyruski
The nismo clutch cylinder will also suit
  • Nissan Skyline BNR32 GTR (RB26DETT, 08/1989 - 01/1995) (Notes: 02/1993 - On, Pull Type)
  • Nissan Skyline BCNR33 GTR (RB26DETT, 01/1995 - 05/1998)
  • Nissan Skyline BNR34 GTR (RB26DETT, 01/1999 - 08/2002)
  • Nissan Stagea WGNC34 RS-Four (Series 1) (RB25DET, 09/1996 - 08/1998)
  • Nissan Stagea WGC34 RS-V (RB25DET Neo 6, 08/1998 - 10/2001)
  • Nissan Stagea WGNC34 RS-Four (Series 2) (RB25DET Neo 6, 08/1998 - 10/2001)
  • Nissan Stagea WGNC34 260RS (RB26DETT, 11/1997 - 10/2001)
Great for heavy duty clutches (larger bore)
