I did for the helmet, and can get the size of the jacket for anyone actually interested in buying it. I'm 173cm tall 78kg, average upper-body measurements, and it fits just as well as when I bought it weighing only 70kg.
Yeah but I want to head down the coast this weekend and my exhaust it leaking and too low to the ground.
Tried to go to the exhaust place today and he said that it's too large for him to work on
Heard that one a few times. She had no say on the matter anyway.
  • Like 1
Roadway is not busy today, got mine done thismorning.
And he wont say its too large, lol.
Too large to work on... thats what she said...... :P
Edited by D.I.Y. Mik
600 CC Siemens Injectors for RB25DET R34 NEO Motor.
Body Design: STANDARD-length, composite plastic
Flow rate: 600 cc/min, 57 lbs/hr at 43.5 psi
Injector type: Saturated
Configuration: Standard Length - 2.5 in., 2.0 in. o-ring to o-ring
Connector type: U.S. CAR (New-style V=EV6 / Oval / LS2)
Fuel Nozzle: Single-hole, tiny droplet
Resistance: 12.5 Ohms, high resistance
Diameter: 16 mm
O-rings: Viton, Top and bottom, 14.5 mm
Part number: 109958
SETS FACTORY-MATCHED TO BETTER-THAN 2%
Sell for $300
0421 669 603
For sale:
Greddy catch can. 1L capacity. - $50
HKS Super blow off valve with pipe (This is the first gen model). Suit Rb26dett. These are non flutter type (Just dumps the air in 1 go) Atmospheric. These are the high load BOV for use with more power -$100 for both with the pipe.
Standard RB26dett Injectors - $250. Also have fuel rail to suit if need be.
Standard R32 GT-R Airbox with new filter. $200
Also have an old boost controller with everything for $50. Can check what it is if anyone is interested. Worked fine before i put my new one in.
Also have Two apexi pod Filters (used) someone can have both for $50.
Can get pics of the other items if people interested.
- Apexi SAFC (Black) - $250 used
- Greddy Profec B Spec 2 boost controller- $300 used
- GCG GT30 0.82 rear housing (internal wastegate) - $350-$400 NEW
- wastegate actuator 12PSI w/bracket - $100 NEW
- 5 bolt dump pipe - mild steel - $150 NEW
- SOLD
- Oil cooler/relocator kit (fits RB) - $180 used - SOLD
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- SOLD
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
- Nissan R31 Skyline Wagon (Series 3) - will confirm K's (under 200), motor very healthy, very tidy apart from a few small dents, Auto, Cruise Control, Alpine CD Player - $1200 ono
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-48292800-1365815283_thumb.j post-27427-0-70125000-1365815385_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
