hey man do you have any photos of it on the car? do you know if having the nismo front bar affects it fitment? where abouts in canberra are you located?
Have an Ogura push type twin plate clutch here with plenty of meat left on it still. Not using it anymore as I've gone to a quad plate.
Suitable for an R32 GTR.
Don't have the bearing from the centre but they're not that expensive or hard to get. $400, prefer local sale.
Also...
https://www.allclassifieds.com.au/cars/bmw/1996-bmw-318is/ad42a87196ea9fc04a688852cf34596444f6?viewstatus=9ff4bfe7fa9f4a97bc01da9176eb8a0f
Rego on Beema until end of March.
Desmond Regamasters
Anyone in ACT after some nice light wheels?
rough tape measure offsets
17 * 8 +30
17* 9 +38
overall good condition, couple of scratches and minor rashing as per pics.
front tyres are 225 yokahamas with some tread
rears are unroadworthy
Looking for $1800
Located in Canberra
Pm for details
Price drop and additional picture taken today added to show condition. Will take $1350 from a Canberra buyer.
PM me if interested.
Hi Guys,
R32/R33 GTR Apexi Power FC (without Hand controller) $600
2x Z32 AFM (Practically Brand new, done like 2000km) $250 for the pair.
Also still have a set of standard injectors, Standaird Airbox (missing 1 clip) and a set of Apexi pods. PM for more details.
Bamp...
$500 for the PFC
and $200 for the Z32....
Selling my R33 Trust "style" front bar
Going back to standard, has a little crack on the passenger side and a few scrapes
$100 ono comes with some LED indicators
Looks like this
10685499_10152383036786699_4246319554620
Still have this sitting on my back deck.
Would like it gonski
$50
Beema gone but still have the clutch! Awesome clutch, surely someone wants this.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
