Thanks Chris!!! I'm checking out one tmw. If no good we will talk. I live about 500m from you so that's handy! Why you no drive Skyrine on track??
Oh that is handy!
Runs out of rego tomorrow, im between jobs at the moment and the piggy bank is running dry :(
I'll be renting a car to share with two other guys so we'll see how we go in that! :D
Thanks Rob,
I've sent him a message. I think those ones are about $100 new so I've offered $75. See what happens.
Greekos had a nice one that I would have paid $100 for but it fouled. Pretty dirty as it was quality.
hey guys anybody want a r33 shell, i have two a series 1 and 2, both have compliance plates
series 1 is rolling and the series 2 has no suspension, both have no interior but they have glass
any offers call me on 0403281331
hi there
i have for sale my whole turbo setup - for my RB25det
Garret GT35/40 - oil and water cooled - braided line for oil and heat protected line for water (turbo is approx 2 years old - was in box for 9months and has done less then 2000kms)
high mount manifold (unsure of brand name -) queanbeyan engines strengthen joints for me)
50mm turbo smart waste gate - one tune and less then 500km on it
all plumed into the dump pipe wich was made to connect to most exhusts.
have owned most of this stuf for two years or more car was covered and locked in the shed for 80% of the time - not useing it and have moved on-
wanting to sell as a hole set up (will seperate if not sold in a few weeks)
looking at $2000 locates south side canberra
i also have a real Gready RB25det manifold has a 90mm throtle body with it - will aslo sell adaptor for so you can use the standard throttle body
$500 ono
please PM me or my number is 0423730741
thanks Reese
Does any one local have any injectors available to suit rb25/sr20 (factory rail sidefeed)
I need 600cc or bigger
Nismo or simular 740cc would be perfect.
Need asap to get the car tuned.
Ive already got ripped off once this week by some asshole who sent me nissan 260cc's from a n/a RB which were sold to me as nismo 740's... :(
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
