Hey all, I sold the stagea and have some parts id like to sell so i can get parts for my wrx.
- I have Sard 720cc injectors which I got on Sinista
- Brand new Nismo FPR
- Brand New Caster Arms to suit R33 GTR unsure of brand
- OS Giken twin plate clutch requires rebuild
Let me know if you'd be interested in them 0408513746
Edited by Verms
Set of 4 Starcorp Pro V 5x114.3 18x8 +38. made in Taiwan.
I was going to fix these up and put them on the B17 Pulsar, they have minimal rash but some scratches on the faces and have just a light coat of silver over them for a temp fix.
(overspray included)
post-78856-0-79972700-1429423411_thumb.jpg post-78856-0-02928000-1429423452_thumb.jpg post-78856-0-61193300-1429424082_thumb.jpg
225/40ZR18 all round. 2 x Federal 595 and 2 x BCT S800.
Federals have heaps of tread, BCT are just above the marks.
$200 ono.
Set of 4 "ASSO" rims only. 5x114.3 16x8 +36. made in Japan.
These were the rims on my R33 when I got it.
post-78856-0-88871100-1429423476_thumb.jpg post-78856-0-76502600-1429424116_thumb.jpg
Powder Coated Grey with some scratches / marks.
$250 ono.
Set of 4 of these... Toyota Tarago? rims. 4x114.3 14x51/2 +27 made in ya Mum.
post-78856-0-14911200-1429423374_thumb.jpg post-78856-0-58161100-1429424821_thumb.jpg
Tyres are no good.
$50 ono.
Garrett GT30, 0.82 rear housing. Internal wastegate.
$230 - Pick-up from Canberra preferred, can post at buyers expense.
Item has never been used, it was part of a GT3076R kit purchased from GCG a few years ago.
Please Pm here, or call/sms 0431900505
Was chasing after this almost a year couldn't find one so i bought one for $800 brand new :(
GCG told me that garrett discontinued making this type of rear housing
Ah damn it, it was you id spoken to!
I thought id sold it but I found it in the house move. By then I couldnt remember who was looking for one.
full set of 6 standard rb25det injectors with rail and reg.
one injector is suspect...I dare say just gummed up due to sitting for months with e85 in the tank and will only require cleaning.
but selling cheap due to the unknown nature of the problem.
$40.00
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
