I'll have a look around. I fairly certain I have couple stored away.
At a minimum you can test to ensure that's your issue.
That'd be brilliant, have traced the non starting back to that, hope that is the issue, hapy to bug/borrow/rent Cheers! :)
I work in Woden and live in Oxley, friensd in Belco so whatever suits u best Cheers
I'd love something like the wagon, but i need to find one in the couple of hundred dollar mark :(
Wrecking R34 GTT. Been in a crash so front end and drivers side parts might be damaged.
4 inch cat back exhaust
BC Coilovers
Rear Windscreen
Drivers door (glass, regulartor, trim, switches etc) can separate
Passenger door (glass, regulartor, trim, switches etc) can separate
GTT wheels with tyres
Boot lid with wing
Fuel tank
Manual Clutch pedal
Manual Brake pedal
Stock Knuckles
Passenger LCA
Power steering rack
Various interior plastic bits
Seat Belts
Tail lights
Rear Bumper
Power steering reservoir
Rear cradle (would like to sell cradle with arms)
Diff
Axles
Fuel tank (has new cap???)
Tail shaft
ABS unit
Rear brake calipers (can include drums as well)
Brake master cylinder
Passenger quarter panel
Side skirts
Air box
Gearbox (maybe)
Clutch/pressure (plate good, pressure plate is not so good)
Can cut body panels
The engine, loom, computer, front calipers, front seats, dash cluster, fuel pump, side indicators as not available.
The car hit a concrete barrier, it has been bent like a banana. Driver corner was hit hard.
I've sold a couple of things already but feel free to ask.
  • Like 1
Sorry, I've some how skipped visiting this forum.
- Yes, it has a double dinn face panel.
- I will check rear seat and centre console lid and hinge.
If you like, please call me in the afternoon (midday onwards) on O4O3 216 47O.
TRUST/GREDDY oil filter relocation kit to suit RB engines (I presume they all have the same filter fittings?). Comes with hoses, clamps, relocation plate, mounts (well, everything the retail box contained). Never fitted or used.
http://justjap.com/trust-oil-filter-relocation-kit-nissan-skyline-ecr33.html
Apparent RRP of $389....can't recall how much I paid for it, so I'll just say half of that - $185 ono. Happy to post at buyer's expense.
May be interested. Still have this?
Hey guys,
might be looking to sell my R34 GT-T 2001 :(
The car has been in a very minor crash at a set of lights, had it looked over by a couple repair places and they have said that the structural parts of the car are 100% fine but it will need a new bonnet due to it being a bit bent and the headlights have small cracks on top where the plastic brakets holding them on snapped.
The car needs to go over registration at the end of the month, and I may be moving so not sure if it worth me repairing it and the rest just to maybe not really need it in Melbourne.
The car is mechanically great, and also is almost completely stock so would be a great starting point for someone wanting to build something amazing!
I really don't want to sell it, I payed $14,000 for it last year, but I also think it would be best with someone who could apprecaite it more.
I'd much rather sell it on here to someone who I know will take good care of it, and I don't really know how much it would be worth as I've heard offers from $1000 all the way up $7000.
I wanted to see if anyone would be interested in buying it or swapping for something more suited for what I need, like a Subaru Liberty or something.
Thanks guys, if you would like photos or have any advice please feel free to message me!
EDIT: Also in case you were wondering I didn't have comprehensive so my insurance wouldn't cover my car, only reason can't get it repaired as I was the one repsonsible.
Edited by Tudisco
Hey guys,
Hmmmmmm
if only i wasnt kesh strapped....
Hey guys,
PICS Please
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
