  • 3 weeks later...
For Sale:  a set of 17x9.5 +35 & 17x8.5 +35 Work Meister Monoblocks in black.
Have looked for similar wheels to set the price but have been unable to locate an equivalent ad.
Last I saw an ad for them in this size was around $1800.
They're super light and I would love to keep them but need wheels for new car.
Edited by MANG
forgot info
Hey guys,
Have an r33 Nismo catback for sale.
Good 3" quiet exhaust. Would pass rego inspection. Centre muffler is a bit crushed, I bought it like that.
$400ono.
Cheers,
Chris
Hi guys.
Chasing a non neo rb25 head for a rb25/30 build. Prefer something rebuilt.
Just bought a gtt with an rb25/30 in it and just found out there is a crack in the head. Can't be welded. Thought it was just a gasket but unfortunately not.
Send me a text or call if you have something of use.
Thanks in advance.
Dean
0434497483
  • 1 month later...
For sale: for you ACT GTR/RB26 nuts.
1 x Trust intercooler. 600x300x65mm. The usual finning that has been folded due to road use, I had this fitted to my car for 14 years with no issues. Whilst I never removed the original Intercooler to replace it with this one, I'm lead to believe this was a direct for to the standard mounting points.
AP Racing triple plate clutch + flywheel. I never had this in the car, but I'm told by the previous owner it was a) built for big HP uses(obviously...) and b) it was HEAVY if you were considering fitting it to your daily...
I don't have many more details on either, but rest assured they haven't been used much as the car hasn't been on the road for 11 years and the clutch was never fitted in the first place.
$250 ea not negotiable or $400 for both not negotiable.
I thought I'd offer it up to the ACT crew before I list it nationally on SAU.
Cheers, Jayce. d5b968f53119a60857a8318dcd5b21a5.jpg02dfc5cbc22b1b670cf3ee94f2f734a1.jpg
Might be interested in that clutch, as i suspect my nismo one wont hold much longer. Any hotspots or anything?
Sorry from the late reply! Damned notifications not coming through...
It's never been apart since I've had it; it was too heavy for the previous owner so he had an easier one fitted and gave me the AP when I brought the car in 2004. I was keeping it for a higher HP application, but my needs have changed(plus not having the car on the road...for 11 years and counting), hence why it's up for grabs. I can't truthfully say if it has got spots, but it would've needed a heap of abuse from a 1000hp car to do so, and that isn't my car, so I'm confident in its state! Feel free to have a look if you want!
Ill pm you.
  • 1 month later...
Hey all,
Selling Whiteline sway bars to suit r33 gtst. Brand new, never ended up installing them.
BNF24Z 24mm 4 point adjustable front - $250
BNR11XZ 22mm 2 point adjustable rear - $200
KLC108 Front sway bar links - $120
Happy to let it all go for $500.
Can supply photos if requested.
Cheers,
Chris
On ‎3‎/‎01‎/‎2017 at 2:45 PM, Sinista32 said:
Folks - clearing space
Let me know if your interested in these - FOC for ACT folk (must have a 32 though)
FOC = Free of Charge
No takers going in the rubbish. Would be a waste :(
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
