Anyone bought one of these Apexi pod filter kits that bolt on to the AFM and have a direct dyno comparisson to before and after, with nothing else changed other than the removal of the oe airbox and the fitting of the kit?
I'm considering buying one, but I'm not sure if it's worth it. Keen to hear of anyone's results.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/
  • Replies 65
Without a heatshield, it will cost you a tiny bit of power, with a proper heatshield and CAI it will make around the same amount of power as the airbox. The pod will make for a lot more induction noise than the airbox as well, up to you if you want that or not.
Check these vids out if you have a bit of spare time
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363349
Mate there are many differing opinions, however if you put a pod filter on, the air intake capacity increases. You will see no gain by simply changing from standard intake to a pod. You need to improve airflow capacity from intake through to exhaust. Meaning if you have a larger exhaust from the turbo back then a pod filter will certainly help. The stanadard airbox alone is restricting air flow.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363739
How will it increase airflow, by sucking hot air? Not filtering dust out? Pods usually have less surface area than the stock panel filter.
My opinions are based on experience. Stock airbox/cai ftw.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363753
An old argument but do you have evidence for this? I am sure there is a point at which the stock airbox will become a restriction but I suspect it is somewhere way past 300kw.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363789
I agree Bob, I guess it will flow well over 350, I know mine can and it uses the same panel filter. Save your coin for a good alloy intake and bellmouth dump/good exhaust. The tuner will take care of the rest.
If you want more power than that you would have to look at a twin pod setup and cai like this one I made for a mate's supra, it just put down 550kw last night.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363807
CES racing have proved this with substantial evidence... Its interesting how these videos of proof by mighty car mods are hardly mighty mods. They use an R34 with pod then restricted air flow from the turbo to the cat to a cat back exhaust, that right there is pure wank factor to replace an exhaust from the cat back and leave the other half chocking your airflow. Then in the other video its the blue turd, this car is running a standard exhaust of course there will be no increase in power...
Hardly proves anything... The surface area of a panel filter may be greater than a pod but the shape of a pod causes a greater turbulence thus increasing the flow... The standard airbox was designed to restrict airflow to minimise the sound levels.
Why dont you just say that a larger exhaust will do nothing as well... If you believe that the exhaust being larger will increase power it only makes sense that an unrestricted air intake will help with the flow of air...
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364072
Its true the above videos are not that scientific but they do represent what a lot of first time (especially Skyline) owners do - get a pod filter and a catback exhaust - closely followed by a noisy aftermarket bov.
Its not a matter of belief... its measurement that counts. There is plenty of research to show the optimum size of exhaust pipe required for different power levels. Similarly the size of air intake is important too and the restriction provided by the air filter ( I am assuming you do not advocate running with no airfilter on a street car) is minimal and the measured difference between pod and stock airfilters is even more minimal. The stock airbox and snorkel also has a small ram effect which helps with flow.
Do you have any evidence to support your assertion that "the shape of a pod causes a greater turbulence thus increasing airflow" (actually that's two assertions)?
When you are running a huge turbo that requires a 100mm or bigger intake then it can become impractical to use the stock airbox and you will need another form of cold air supply.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364241
The airbox is unrestricted, its the intake that thins down to 40mm and requires upgrading. (not with the stock turbo though.) As Bob said, when you decide to build the engine, run a 3.5 inch exhaust with no cat and run a 600hp turbo, then you will need to look at the airbox being a restriction.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364607
turbulent air actually has higher resistance compared to laminar flow, plus you run the risk of getting an uneven air flow over the maf
know much about reynolds numbers?
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364610
Im sure my TO4Z dragging in air at 24lb would be creating a bit more turbulance than a little bit of wire in a POD, a POD is only a advantage if it has a heat shield and CAI on motors that need more unrestricted air flow, try doing a hydrometer test on the intake pipe to see any difference.
Results cannot be taken on the dyno, results need to be done whislt the car has the bonnet down on the road/track, if you want a accurate result do a hydrometer test, otherwise you are just pissing in the wind.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364633
Why?
Close the bonnet and let the dyno fan run. The Mainline fan blows air at the car at 100km/h, which is exactly what you'd see on the road/track whilst driving at 100km/h; I dont see how its different.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364642
I have a HKS Mushroom Pod. I don't have a lot of choice regarding the room I have - the cooler piping runs right through the place where the stock box sat.
I also made sure that I have a large amount of fresh air feeding it- up from the fnt bar. I don't really understand the HKS specific pod bashing. There may have been ones that fell apart after X years. Thats really not a good thing. But they do have a 3 layer filtration foam, its not just that coarse layer you see from the outside, which wouldn't filter well at all. Same quality as a panel? Probably not, but its not as hopeless as people make out.
As for temps- on the freeway / moving I've been seeing 22-25 degrees measured basically at the throttle body. My AFM is after the filter/turbo/intercooler. I'd say thats pretty acceptable, and its not sucking in hot air.
However, If I had a choice, it'd be to keep the stock airbox/panel. Getting a pod for the sake of it, just not worth it.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364883
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
