Well, Ill just jump in and say this before some dickhead says it..
"Just do a line locker bro .. just do a burnout .. der"
I know this isnt the answer your looking for, so the only other way that i know of is..
Get your car up on a hoist, and then attempt to spin one rear wheel by hand, if the other wheel spins at the exact same rate, you havea LSD and its fine..
if the other wheel spins and is kinda joly/grippy this means your LSD is on its way out .. proberly a busted side arm or teeth being chipped off
(Note: Exercise only practiced on race tracks)
Naturally.:rofl:
Yeah, the viscous LSD always seemed to have a mind of it's own as to how many wheels it would spin eh, but we shouldn't be using these fine Nissans just for smokeshows now, should we? :D
But you're right, the question was to check for an LSD, and jacking it up and spinning the wheels is the best way.
Perhaps there's a cue to the internals by looking at the back of the diff housing?
yes that's the best way.
That doesnt make sense.
If you spin one wheel the other wheel will spin in the same direction if it's LSD.
If it wasnt originally lsd one wheel will spin in the opposite direction to the other.(single spinner)
However you'll find that most skylines come with lsd.
If your spinning one wheel and the other is spinning in the same direction but not at the same speed it might not be working properly.
if you wanna find out if your car has LSD then you could give your VIN to an authorise Nissan Japan service center (or any Nissan Dealer in australia) or infact anyone with the NSSAN Japan FAST system, they could plug it in and let you know if your car got one from the factory.
When I first got my car, I got it serviced and the dude goes "wow you have an LSD on yours". And I was like "huh? don't they all have em?" (coz I had a viscous LSD (2) on my ex-drift 180sx). He informed me that not all R32s came with an LSD, so I checked up on mine at my local nissan dealer n found out that mine had a factory LSD (dunno if its 1 or 1.5), and not only that it was a limited edition V Selection 2 which was given the trimmings of a GTR and LSD n HICAS n strutbars n all the goodies lol
Uhh.. i Thats exactly what i just said ... wasnt it?
Edit:..
Thats pretty much the exact same thing i just said .. how does it 'not make sense'
lol now youve got me confused :D
The ECR33 (R33 GTS25t) has a factory LSD (8/93 onward).
From I think 95 onwards there was a factory option for an Active LSD which is obviously better than the standard LSD in that there is some sensors and a computer to control the way the LSD works.
The easiest way to tell whether you have active LSD is to look on the dash and if there is a SLIP or A-LSD indicator in the middle you have A-LSD.
Very few cars have the Active LSD so don't get your hopes up.
Ok then.....
like I said before an lsd has both wheels spinning in the same direction at the same rate.
Single spinners also spin at the same rate but in opposite directions.
Hope that clears things up. :(
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
