so my R32 GT-R developed a light load metallic rattling sound a few months ago, i drove it occasionally knowing i'd most likely be up for a new engine soon. the time has come. the sound is bottom end and getting louder and deeper :(
it's a 1989 gt-r so i was wanting to upgrade to at least a late model rb26 for the better oil pump drive gear and just wondering what problems i will come across. if i go late model 32 gtr engine, will the early push type clutch gearbox bolt up the same? what if i ended up finding an r33 gtr engine? will i have problems then?
if i upgrade to a late model 32 or 33 engine, will my ecu be fine? or will i need the r33 ecu if i upgrade to a 33 engine?
are there any known hassles in this department of changing to a later model motor? is it best to just rebuild mine? (nearly a 3rd year apprentice mechanic and would love the challenge but it's not beneficial if the late model upgrade is worth it)
if i go an r33 engine, is the front diff the same? or will i need to swap the internals from my diff to the new sump? or just swap the whole sump over?
any help you can offer would be great!!
álso, any reccomendations on where to buy a new engine from that i can trust will be good? or should i consider buying a new bottom end only and swapping my head over? if that's a better option, will my head be compatible with all model rb26 bottom ends?
https://www.sau.com.au/forums/topic/401238-need-a-new-rb26-few-questions/
the long motors are all the same, in fact I just put a 33 motor in my 32.
You will have to watch out for diff ratio and CAS if you use a 34 motor, and some wiring differences if you use a 33 or 34 motor. In either case just swap across the gear from your 32 motor.
Assuming it has a f**ked bearing, do not re-use anything from the old motor that had oil in it. Or if you feel brave, stuff like the turbo oil feed and return, and the turbo cores themselves may be useable with a really good clean (probably not). Never ever reuse the oil/water interchanger under the oil filter, you will never get the inside of the oil part clean.
thanks for the reply. i put two brand new turbos on in november and haven't driven it more than 2 thousand k's i reckon so i'll definitely be swapping the near new gt2860 -7 turbos over to the new motor. the bearing noise is still quiet, it certainly hasn't actually let go yet so providing i pull the motor out before it gets much worse there will be no problems with them. but also, hadn't really thought about that side of things so i will be making sure my turbos are not contaminated before i install them on the next motor. how did yours go? the 33 motor easy to swap to?
yeah there were no issues, everything bolted over fine. Just lots to do.
BTW, mine had a spun big end bearing, no knock at idle, only when revving. it looked like tinsel inside the sump. you would never believe where bearing material can get to.....
I have also lost the turbos 100% of the time I have re-used them from a motor with a spun bearing within a few thousand klm. These turbos I cleaned out like crazy, as best I could without disassembling, and they have been OK for 500klm so far. Still far to early to call it a success though. Also, I changed the oil and filter after 50 and 500klm as well. You can't be too cautious when the turbs are worth 1500+ to rebuild
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
