Hey SAUers, I'm not sure how best to describe or if others will understand, but I'll try!
At high speeds, 100kmh ie, even going along straight the car seems.. unstable. Not that it jumps whole lanes, but it feels to me at least like a spider on a hotplate or on ice.
And yesterday after driving in St Kilda for a while on REALLY bumpy roads, it was even happeningish at lower speeds. Once I almost sideswipped a car next to me (I was inside lane, thank god it didn't go over to oncoming traffic), the car just suddenly started going left and I had to turn the wheel right.
Anyway, it is at mechanics, hopefully they find a bush missing or something extremely loose, but does anyone have any ideas?
I realise it is a GTR and has tight suspension and so on, but it seems to me that it isn't just being sensitive to the road.
Cheers!
Don't know about lock bar, but I'll relay that it could be HICAS.
Definitely makes sense that it would be HICAS, as it is definitely some sort of weird steering thing that doesn't affect the steering wheel itself.
Oh another thing, it also seems to happen more not just from going over bumpy things, but by fanging it. IE 1st 2nd to 100kmh, it definitely feels wobbly.
Hicas eliminator is good because it eliminates the outer tie rod ball joints.
More expensive than a lock bar but cheaper than tie rods and ball joints
Those outer rear hicas ball joints are expensive and hard to find.
I think the bearings are ok. Both rears were replaced like 6 mo ago. Bushes should be OK, lots were replaced 6 mo ago as well when I replaced much of the rear.
I'll see what they say then perhaps think about lock/eliminator. I don't really plan on racing or whatever so I'm not sure the pros or cons of having it in for the street, but if it isn't much more then I guess I can go for it.
Meh I'd rather avoid defects to keep life simple.
What does it really do to the driving experience? My mate loves my car and he's got a massive single turbo 1JZ MKIII supra with a crazy diff (only goes to 45kmh in 1st lol) although i suppose his suspension is older and not as good.
Mk3 Supras are a little crude in the rear suspension, but not terrible.
HICAS is intended to produce slip angles at the rear as you turn in, to make the car more responsive to changes in direction. It is also supposed to make continuous small tweaks to the rear steering throughout a corner to keep the car on line. In reality, whilst it may enhance turn in (desirable), what it really does when you are fanging is make the rear do things that you were not expecting. Makes it very uncomfortable to drive fast. And that is while the system is still working properly. Once it starts to f**k up, all bets are off.
They re-aligned it.
It seems better, but still is a massive problem. Twice tonight on the way home along royal parade the car had a mind of its own and decided to 'jump' to the right. Thankfully they are only smallish ones and I react in time, but... damn.
What size / width tires are you running? Wider tires with a lower profile tend to "tramline" or follow the grooves in the road. Wide semi slicks are notorious for doing this, and the car feels like it pulls randomly when it hits a different angle on the road surface. Wide street tires tend to have the same effect.
I'm not sure I will check but they aren't low profile. 265R19 I do believe.
I'm starting to think its gotta be something in the suspension and steering rather than the wheels because sometimes when I break (sometimes heavilyish) the car will pull to the left/right and the steering wheel will actually turn a fair amount as well if I let it.. perhaps?
They re-aligned it.
Can you post how much toe in they dialled in - I had my car aligned too when I just bought it, felt shocking to drive - tramline central, then I went back to the alignment place and checked the toe in, which was left at 0 - now its 1mm or something like that, sensitive but much better.
265's wouldn't help much either - tramlining you all over the place.
I had the same issue with the hicas, after 70km or so it would just kick the ass out but always the same way, i believe the drivers side rear...would slide to the right, very scary, i had the whole system removed and the lock bar installed. I would have rather keep it, but just way too dangerous.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
