Yea its definitely still a problem, sometimes the wheel is perfectly still, yet the car feels like a puck on an air-board and just gliding along with my not having any say. Last night going along at only 70kmh the car definitely wanted to go right, I had to seriously turn left and then back to center to get it right :/
OK, so .... what steering wheel do you have on it? More importantly, is it HICAS compatible?
Have you tried to start a HICAS diagnostic? (google it).
Do you know anyone (mechanic) with a proper scan tool that can report on all the computers in the car? My mechanic has one that reports the computers in the car as being Engine, Trans and Steering (trans because R34 auto ECU has trans module in it - even though I'm using it manual) and my HICAS computer is still present but only partially connected (and completely disabled mechanically). That scan tool reports available fault codes for those computers. Worth a look. You can't always start a HICAS diagnostic to find out if your steering sensor isn't working (for example) because you need the steering sensor (and others) to be working in order to get a diagnostic running!! So scan tools can be a lifesaver.
cheers
Glad I found this topic because my car is becoming increasingly deadly on the road.
Going to be looking at delete or lock as soon as I get some cash.
Would you suggest a delete rather then just the lock bar?
or can a lock bar still bring it stable.
I jacked my car up and you can actually move my wheel because my hicas is so loose..
Don't know on R33s. I put a whole non-HICAS rear subframe from a Cefiro into my R32 and pulled out all the HICAS stuff completely (of which there is a lot more in an R32, being hydraulic).
It's also closer to being legal, as HICAS lock bars are considered a modification to the steering system, which is generally a no-no and an engineering exercise at best.
If I were not to have done the whole subframe, I definitely would have bought one of the more serious delete thingos that replaces the HICAS tie rods with arms with bushes on the end.
Standard GTR wheel from what I can tell. It is possible some sensor is broken or stuck, as for diagnostics I don't think they checked that thoroughly as the loose camber nut was found. But yea I might ask them to do that, I'm sure they have the tools.
These symptoms (or at least the one posted above this post) are usually caused by the steering angle sensor....and more particularly by not having a boss that drives the steering angle sensor.
I thought the same thing but the original steering wheel and boss were in place, I don't believe they had been tampered with, it was intermittent and there was no way to guess when it would happen, either way, all gone, all good.
OP, if you can, just get the system removed and a lock bar installed asap, at least the car will be safe to drive, I know how dangerous it feels, good luck!
Edited by ima_slap_joO
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
