Great result mate. Congrats.
So it's hitting full boost by 4000rpm.
That's pretty damn good, especially when you are running the stock manifold and the gate off the turbine housing aren't you?
what size exhaust are you running?
Not sure on the road speed conversion to rpm but it seems to be hitting 16psi at 4000rpm; 16psi is the boost level chosen not 'full boost' capacity of the turbocharger and system. Don't mean to be picky but its good to know the difference as it can be misleading.
If it were to run more more boost, it would take more rpm to generate that additional boost. Basic eg, full boost could be theoretically 45psi + and at that boost level, it would not hit that at 4000rpm but more rather 5000rpm or so. More relevant, if they were to turn the boost up to 25psi, they might see that figure anywhere from 4200rpm to 4500rpm.
  • Replies 94
Glad to hear you got it sorted mate. great result!
Really makes me think about adding the juice to mine too. Be really interested to know what the higher compression would do with it.
How much would you estimate the additional costs were? do you have a ethanol meter? tuning etc?
yeah 20psi at 4000rpm and yes stock manifold and gate off the housing, i have a 3 1/2inch system and 3inch muffler ,
Edited by SliverS2
thanks mate, the juice had the tuner shaking his head laughing, he did the tune in about 45min which was pretty good going,
injectors and rail - $830
fuel reg- $270
modifying manifold -$50
others hoses,fitting ,fuel etc -$200
tune$200-$300
shit sounds like alot, best not thinking bout the total :closedeyes: dont have an ethanol analyser, its been tuned on the richer side and im just going to keep an eye on the knock levels.
Edited by SliverS2
Im well aware of all this, but full boost to me usually refers to the maximum boost setting the owner has choosen to run for the supplied dyno graph. For the more novus reader though, i can understand where you are coming from.
I think 4000rpm is decent considering the flow capacity the gtx3076 has, I'd be stocked with the result. Wonder if the poncams made much of a difference?
i just looked one of the video's i took , its actually before 4000rpm, ill try to upload it to show proof of the road speed v's revs,
it looks like 100km/hr is about 3500rpm in 4th so if thats right then i have 20psi at about 3800ish
Edited by SliverS2
haha.. even when cruising its like a kettle whistling and whining , dont have need for the radio much these days lol :whistling:
Haha nice result man! Gotta love that sound!
Your standard engine will take more boost and love it ;)
cos of the internal wastegate
Its an external wastegate, tial 44mm with a 0.82rear housing , i doubt it could ever fall over
It looks that way because of how the boost controller was set, i put in 90%duty up till 3500rpm to try and get it boosting early, and 60% for 3500-7000rpm
we never touched it on the dyno , just did a run and because the power was what i was after, decided to leave it where it was, there is no problem getting it too hold 20psi all the way thru if we wanted to, but this way the engine isnt being leaned on so hard toward the end of the revs, so a quick adjustment on the controller would see 350kw probably, but i dont want to be rebuilding an engine for a while yet so will just leave it for a while. :yes:
Edited by SliverS2
For ARTZ, I honestly think the external gate setup here helps with how impressive it is.
The internal gate would be a different story, a little lazier IMO.
Im pretty sure Mick_O is on par for spool with this car but has a GTX71, i dare say if he went external gate off the housing his spool would improve again.
the answer was for the hks pro s (r31 power)
I went for a nice drive in Mick O's GTX3071 R33 today and am so blown away at how good it is that I honestly cannot see how he could improve such a potent weapon. Running e85 and an incredibly fast spooling gtx pumping 330rwkw it had me laughing madly all the way and being the really nice bloke that he is, he was laughing as much too! Thanks so much Mick O, Ur setups just so amazing.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
