Now they're thinking...
I can get a pair off easily enough > but who do I know that can drill a hole to make an earring?
And that fellahs...
is what happens when your lovely Nismo items are so small and defenceless!
Ummm white spoke stickers? Again Chris, I'd PM elrodeo666 and Marcus will do his best - quickly!
...or eBay. But some stickers can be a fraction too big > need to be the right size if you can.
  • Like 1
If you mean the Nismo wording on the LMGT4, I wouldnt bother with genuine stuff personally.
The last time I enquire about that, you'd need to get them from Rays and they're around 25 or 30 EACH + you need to provide prove of owning a set of LMGT4 (maybe invoice, photos?) before they will sell them to you. This was 2years ago though.
I end up getting the decals from Ebay. All you need to do is measure up the existing one you have and send the dimension to the seller that makes a Nismo decal. Less than 10bucks posted.
Thanks heaps for that!
Do you also know if Nismo sell the white stickers for the Balck LMGT4s?
I gotta say - don't bother getting the nismo wheel valve caps. I had mine on about a week before they were stolen.
I'd only thrown them on after I'd chucked them in on order from RHD with other stuff because they were so cheap - and thought they might set off the LMGT4 and nismo wheel nuts. Ah well.
I recently ordered 4 of these through Streeter, and there was none of this hassle. they cost around 20$ each.....fml but having said that i think i'll get Ebay ones next time!
i have a set..and i'm contemplating whether to put them on or not =(
mm cant help you much there, im pretty sure with the Rs they mount from the passenger side vent on the front bar under the indicator light, but you need the nismo front bar for the outlet just infront of the wheel behind where the cooler sits to actually allow air to flow through... if it doesnt work out on your i would be interested init... but im broke atm anyways haha
haha yeah i've looked up the pics on a GTR and it's slightly different as they seem to have a mounting bracket/bar, i swear this item was advertised for a GTT when i bought it (from Japan)! quite confused. Oh well, will have a look one weekend/when i install FMIC.
  • 4 months later...
available for all models. expensive though for what they are - a cover
Edit: (I painted mine black a while ago and it looks 10x better than the OEM grey)
Now this has come out I'll give it thought.
Edited by Sinista32
Nismo power brace, to suit my 180sx. Nismo take the old stock units, box the sections and add a bar between the arms.idea is to stiffen the front up to prevent flex and make the susp work harder. Finish isn't crash hot, but since it's a under car bit, I'm not fussy. In fact I'm not fussy anyway lol! Basically acts as a strut brace for the lower suspension.
So are they pre-fabricated or do you have to send in your old units? Pretty cool piece either way.
You just buy them, no exchange needed. Guess they go round stealing them off old wrecks and old Oem stock!
Can't work out why one side of the bar is braced extra, but guess they know.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
