Love the white on white terry, imo much better than the black. Makes the black or carbon nismo skirts look alot better too aith the black and white theme. Would love to get a photo of my white s15 on white lmgt4's with your car now.
I've seen your car at a local shopping centre a lot, was having a good look around it last week and trying to pick out all the nismo parts haha. Looks the goods Mick!
  • Like 1
If I didn't (sort of) have a GT-R, I would fancy one of these.
Thanks for the kind words guys, appreciate it :thumbsup:
  • Like 1
Haha the dog is always on the bed!
Yeah they have been doing them for bnr32 for awhile anthony. They are a bit more expensive than r33/34 ones though. I wonder who is going to be the first on sau to have the carbon ones though
R32 Link http://www.nismo.co.jp/omori_factory/original_menu/air_inlet_pipe/index.html
R33/34 carbon http://www.nismo.co.jp/omori_factory/original_menu/carbon_inlet/index.html
  • Like 2
interesting
I've seen these in the flesh at the Omori Factory.... absolute works of art! Nom nom nom nom :D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
