Still interested. Is the apprentice wrapping them for shipping like the sway bars?
Lol, he's moved on to doing oil changes on mum's car. :P
I can ask him if he'll do yours, but he's pretty busy... :whistling:
I'm sending them in a cardboard tube actually; so Auspost can't whang them up before you receive it. :thumbsup:
Hi Dale - haven't had a look under an M35 so is the suspension markedly different from the C34? Should I look to getting a front brace made up for my S1 (presuming you are not into making them) or is the set up such that there will be little or no benefit? And why do you not use aluminium - is it not strong enough?
the C34 has a similar setup to the S and R chassis.
the best bang for buck is a similar bar, however, it braces the two castor arm mounts in front of the front cross member. i had one on my S15, made a massive difference, similar to dales brace.
I'm sure there's some benefit in undercar bracing for the C34; but I don't have one to evaluate or measure off, so that makes it difficult for me.
I know there were guys using R33 GTR undercar bracing on Stageas while back; it might be worth looking down that route?
I elected to use steel rather than alloy, because it's definitely my favoured medium; I know I can get excellent strength and good quality welds. Whereas with alloy on a structural member; I'd like to be heat treating them after welding, and that would make them stupidly expensive.
Also, on the brace I'm making, due to the thickness of the alloy required to be strong enough; my thin wall CrMo tube with steel ends is basically the same weight; possibly even lighter. You could virtually jack the car off it; the stuff is so rigid. I wouldn't bet on the same for the alloy one.
As Iain has said; tying together the radius rod mounts could definitely pay dividends, and it is a very common mod.
Will be mitring and welding tomorrow; it's going to be a busy day!
You planning on making 30 more Dale? Didn't think the M35 under body brace market in Aus was that big - or are you going international?
Lol, I had a mate CNC the ends for me; and he did a few extras...
I've got 12 to make this week though.
Edited by Daleo
Yeah, I counted 61 ends (damn ocd) which seemed like a lot, but makes sense once the machine's set up, why not make heaps for later.
Ok, welded four braces yesterday, mitring the rest of my tube today; so I should have most of them finished and in paint by the end of the week!
What's the hold up??? :P
Edited by Jetwreck
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
